sharpening question
sharpening question
sharpening question
Rick Snyder
Hi All,
What is the technique/procedure for using sandpaper for sharpening lathe tools, also, what are the grits used? Are there any indepth videos pretaining to free hand sharpening as I am unsure of myself with this technique at this point in time in my short turning experience. I do have a Worksharp and have no problem with plane blades and chisels. (I have a MARK 11 jig)
What is the angle of turning skew chisels..... 30 degrees?
Thank You,
Rick
Re: sharpening question
Nick Tuzzolino
Rick:
Not sure of your first two questions (dozens of answers available).
I sharpen my skews at a 40 deg (20 deg angle at your grinder) with much success. This is a favored angle of many of the teachers of the skew .
I know this only because I measured them. My spindle gouges are 35 degree. My skews vary from about 35 to 45. It just depends on now I got that particular tool sharpened. They all cut well. My bowl gouges vary with the grind. 45 degrees to 55 for the front bevel on most of them. My rough out gouge is 35 degrees also. At least I think that's correct, my memory is duller than my tools.
I use 120 sanding disc but have gone up as high as 400. When I used my belt sander on it's back I used the 120 or 220 belts.
Nick Tuzzolino
Thanks for elaborating on my comment, John. Nothing needs to be exact here, as long as it works for you. I'll bet my bowl gouges vary in degrees at least as much as yours.
eliot d
Is there a good reason why you aren't using the good old tried and true wheels and a varigrind? Of course you can sharpen any way that gets the job done, but when you get famous and are demonstrating at clubs and the annual meeting, etc. there's only going to be a wheel set up available. ( Actually this isn't strictly true: you can always carry around some wood disks with sandpaper attached and mount them on whatever lathe you're using.) But look, the turning world pretty much has standardized on wheels.
Jerry Hall
Hey Rick,
You have gotten the plain truth when you are directed to standard grinding wheels for sharpening as the gold standard for turners.
In answer to your question tho here is a link to a long discussion on using belt sanders which may relate to your question:
http://www.aawforum.org/vbforum/showthread.php?t=9444
The main objection some have to sharpening with a sander is that it at best produces a flat bevel. Where a grinding wheel produces a hollow bevel. The hollow provides two indexing points for hand honing. Which some do, but many don't. The flat bevel can be honed but less easily. Or with supplemental equipement.
Regarding a video: You can see a bunch of them at my site http://woodturningvideos.weebly.com/ under "sharpening" The one at the top by Brian Simmons is a good place to start.
Choice of sharpening techniques and bevel angles is a lot like choice of religion. Most can lead you to good outcomes, just different paths. Join an AAW chapter and spend some time with a mentor on sharpening if you haven't already.
In any case, keep your tools sharp!
Jerry
Lyle Jamieson
Lyle Jamieson
Jerry, Great web site!! Somehow I have missed it til now. I dont believe I have not seen it before. I hope to have another DVD and a series of utube spots produced in the next couple months.
Creative Lakes
Visit SharpenersReport.com for articles on sharpening woodworking tools. This national trade publication posts articles by professional sharpeners of saws, planer knives, drill bits and other tools.
