Metal vase
clay foster
Another piece that started out as wood and became metal. Pieces of scrap sheet metal shaped on a wood form and then connected with brass brads as rivets. The name is AS, part of an old license plate. 7" high x 5" diameter.
Metal vase
clay foster
OK Clay, you have aroused my curosity ....
JamieDonaldson
....as to how you hammer over the brads inside without driving them into the wooden form? I assume the holes could be drilled through metal into the wood to form the shapes before hammering the brads, but assembling the pieces together without the wooden form would be a nightmare?? Howdjudodat???
Re: OK Clay, you have aroused my curosity ....
clay foster
The brads go through from the outside. I peen the inside end with the head of the brad on an anvil.
But the question remains , how are the ....
JamieDonaldson
...individual pieces reassembled once the wooden form is removed? Metal jigsaw puzzle?
Well I just like it, however you do it.
Re: But the question remains , how are the ....
clay foster
I'll do photographic essay on it for you the next one I make.
Re: Metal vase
Bill Neddow
Was the wood form made from Pink Ivory burl? I'll be disappointed if it was not!~~~~
Fantastic-as usual!
Re: Metal vase
steve worcester
You beat me to it.
clay foster
The pieces are cut, shaped, and riveted together one at a time. I start at the bottom, get the first piece shaped, then shape and fit a second piece, rivet them together, and so on.
OK, so how do you peen the inner side of the rivets? Do you drill the holes, lift it off, peen and return it tot he for for the next piece? On a piece five inches in diameter, how do you peen the last pieces?
These are beautiful.
clay foster
Yes.
I start at the center or bottom of the bowl and work my way out, so I'm always working at the outer edge.
Thanks.
