mini lathe table height question
Rick Snyder
Hi All,
Today I received my mini lathe and I'm wondering what would be the correct height I should be working at with a benchtop lathe. My table is 33 1/4 in. high and from the table top the head stock spur center is at 13 in. for a total of 46 1/4 in. Is that a good height to work from? (I'm 6ft tall)
Thanks, Rick
Re: mini lathe table height question
Skip Beardsley
Hi Rick,
All I have ever heard is that the center of the spindle should line up with your elbow when the lower are is at 90 degrees to the upper arm.
I would think this would be a good starting place. I am tall and so I have both my mini and my 3520 just a bit higher than that and it seems to work out well in both cases.
Hope that helps. Happy turning
Skip
Terry Scott
As per skips suggestion at elbow height
However I have seen mini lathes up way higher than that
I set my lathes up about 1" above elbow height. This keeps my back straighter and causes less pain. Too high and you hunch your shoulders which leads to strain. Ideally make it adjustable by placing boards on top or something like that. Start out at about elbow height and as you get used to the lathe and find what you like to turn you may want to adjust it up or down. YOu don't need to adjust it all the time like moving a tool rest. This is usually something you do if turning feels uncomfortable at what ever height you pick so it's handy if your stand can be easily modified by adding or removing wooden spacers. People who do nothing but hollow vessels tend to have their lathes lower than people who do nothing but pens. However it's all based on posture and what lets you be relaxed. As a new turner Elbow height is a good starting point.
Lyle Jamieson
Lyle Jamieson
A very important issue is stability. A mini can do a lot more if it has a strong sturdy stand/table. You will need the stability sooner or later so get it set up with a big footprint, some extra mass, and leveling feet. Spend some time now and you will be a lot happier down the road.
Steven Antonucci
It depends on your style
steven antonucci
I cut with the handle very low, so I have my center at 43 1/2", and I am 6'1". When I turn on taller lathes, I find that I cannot keep the handle against my thigh as I normally would (long handles too)
More important to me than the spindle height is making sure that the stand allows me to get really close to the lathe. A bulky stand is good for mass, but you have to have access to the lathe too. A big box might make you stand 3" further away, which doesn't sound like a lot, but it also changes how you stand.
No matter where you end up, you will adapt to it, but that's my 2 cents.
Steve
Bernie Weishapl
I am 6 ft and have my small lathe at about a 1" higher at 47 1/4".
Re: THANK YOU!! - mini lathe question
Rick Snyder
Hi All, the info I received was very helpful, I'm sure I will have more questions in the future.
Thanks again,
Rick
Lyle Jamieson
Re: It depends on your style
Lyle Jamieson
Great point Steve, make sure you have shin space so you can stand with your thiegh leaning against the lathe bed or table edge. Bolt the lathe as close to the front of the stand as possible.
