A piece of Blue gum that came from a tree that I cut down in my driveway .Always windy the tree had been compressed at ground level. Normally Blue Gum in Nz splits so badly that I’ve been cutting with a chainsaw and you can hear it cracking over the noise of the saw.
Wet turned I expected to see this piece in match sticks when it dried. Storing wrapped in Newspaper for a year I needed to full my entree spots at the royal Easter show
Typical of me I put in an entry name wood and price before I have even thought about what I am going to make. Makes interesting reading when you are under pressure.
Liking what Joe and Andy and a few others have been producing I thought I’d have a go at bringing out what was obviously beautiful grain but in the raw it seemed fairly plain.
5 Different colours were applied sanding back to 2000 between each staining .Lacquer was then spayed on and cut back with car cutter.
My wife even liked the finished effect which says something.
I wasn’t a hundred percent happy with the shape but I guess the wood did the talking as I received a first in hollow forms at the Royal Easter show. Also a testament to a work is if it sells so I must have done something right.
Comments welcomed (thanks Andy for suggestions on how I can improve the form ) easy for you to say (Grin )
8 inches high and yes I couldn't help using the Textura to add a draw card for the eye
Beautiful color and beautiful finish. Congrats on the win. There's no way I could say five colors were used. I have to ask if you could give more details.
I sanded to 600 wiped on a light color I think yellow was first (but drowned the wood)
With help from the heat gun dried then sanded to 1200 back to bare wood
Then green,blue ,orange, red then black
Opposite way to what most apply as they do darker colors first. Whoops thats 6
On burl I can achieve a marble like finish
I used a mix of acrylic dies EEE and Briwax alcohol based (not mixed together separate and dont ask what colors were which just what was at hand first )
By using the 2 types you get differnt depths of penetration.
