So................ I read the golden rule's for bowls and Russ's other rules for bowls. An I think I get the reasoning. How do they apply to turning plates or platters. A plate/platter is a bowl that is only 1"or so tall.
Dan J.
still having fun working thru my large stack of wood.
There are still many variables to consider. Not as many as with hollow forms or finials. Foot diameter, foot height, overall size, recess diameter, rim diameter, rim width, rim thickness, and detail treatments, grain patterns, color character of the tree, Im sure others will add to the list. It is a balancing act and only you can tell what looks good to you. Do a series and each one will evolve, as you go, to be more pleasing to you.
I am with Jorge here, thicker is better. A plate needs a rim of some sort so when you are out of bread or rolls, you have an edge to push the food up to so you can scoop it up without using your fingers, though that doesn't stop me. I like licking my fingers. 1 inch thick just gives you so few design options. 1 1/2 inch thick can work, 2 inches is better.
I agree with Jorge that 1" doesn't give you much to work with for shape. I use a minimum of 8/4 wood for plates/platters up to 14". I really like 10/4 for 16". I also after seeing a demo by Mike Mahoney make my base at least 65% to 75% of the diameter. So for a 16" plate/platter my base is 12".
Are you turning the bottom outboard or reversed? Seems that on the bottom, going from center to rim would be, um, right to left(?), but on the top, going from the rim to center would be left to right -- at least on my lathe.
I've never thought enough about plate and platter designs. Jamie's reply got me thinking there's more to a nice platter design that initially meets the eye. I have only made a few plates, but I like platters to be a little thicker, like the others. Probably 8/4 to 10/4 for a 12 - 14" platter.
Lyle's advice is the best, he goes to the essence.
I was just talking about the mechanics. I happen to have a platter blank on the lathe waiting for a peaceful moment, it has not happened in a couple weeks, too much else to do....
Here are 2 pics showing how I do it:
As you can see, I use an extension to create a comfortable work space and the cut, from the glue block out, is left to right.
And doing the face is same, left to right. This is a quilted big leaf maple blank, it had a lot of bark and lift fork wounds, so to obviate the temptation of repairs to conserve volume, I did the drastic surgery you see in the previous picture. I think the grain is so beautiful that it deserves to be all clean even if the shape is not optimal.
I like using the face plate with a glue block, because I mount the blank once and work on both sides. once I am satisfied with the shape I clean the foot on the vac set up. Doing platters was what made me get into vac in the first place.
Did you experience any run-out when using the 3" extension? If you do, does it affect the cuts?
I have not done any platter so I do not know the proper way to do it. Can you turn a platter or plate the same way as a bowl? Instead of turning from both sides, can you turning the bottom first and then reverse mount to turn the top. If the blank is 2" think. There should be enough wood to use a faceplate for the bottom turning and a glue block for turning the top.
Starry, I make platters using essentially the same process as doing a bowl except I use a recess instead of a tenon. I use a woodworm screw on my chuck to hold the blank while I turn the base and add a chuck recess for reverse chucking. I use a spacer if necessary to reduce the hole depth if the blank is not thikc enough to accommodate the full 3/4" length of screw. The foot is the same height as the recess so don't really give up much wood. I then reverse chuck to do the face and interior. I use a vacuum chuck to reverse again to do final finishing on the foot to remove any recess traces.
Hi there, hopefully I can make a contribution here as I turn alot of platters in the 14" to 19" range. I concur that 8/4" is just about the minimum, any thinner and there not much room for any depth relief; I also find it difficult to find much of anything thicker that's already dry. L-T-R, R-T-L doesn't seem to matter too much as there will be time you need to go either way just to get things cleaned up. I start out with the blank screwed to an adaptor w/4@#10x 3/4", gives me about a 1/2" bite, not alot but have only lost one out of 30 or 40 platters. Turn the foot about 1/3 to 1/2 the overall width. Chuck recess is about 1/4" to 3/8" deep.
I start roughing at around 250 rpm, work up to about 500 for shaping and 750 or so for finishing cut. Primarily use an Ellsworth gouge w/ a little scraper action or Hunter tool for finishing, really depends on the wood. Cherry, mahogany, walnut, maple work great, ash & beech seem to have alot of internal stress when turned to an average thickness of 3/16" to 1/4 and warp shortly after turning.
My wife likes thin ~1/8" tk platters, but I don't think there will be durable for regular use, so I go for about 3/16"-1/4.
I wish to thank everyone that has replied to my question.
This is one of my 1st plate's ( I see it as a plate). It is 9 inches by 2 inches tall. It's White Oak with a little spalting. I finished it with 4 coats of General Finish " Salad Dressing". Comments are always welcome. It's my way of learning.
The photos might not be your best work, but the turnings are coming along just fine! Did you expand your chuck into that little recess? Would take about 1" jaws for that (?). If so, you'll get a more stable grip with 2" (50mm) jaws, or a tenon turned on a glue block for 2" or 3" jaws.
