Reworking my Tormek
Reworking my Tormek
Steven Antonucci
Reworking my Tormek
steven antonucci
I bought a new stainless steel shaft for my Tormek over the weekend, and I have been slowly pulling it apart over the last few hours. The carcass has some of the green paint peeling off, and a fair amount of rust on it. After I wire brush it or sand it down, I'd like to cover it to protect it a little better than bare metal and rust in water.
I though about mixing up some 2 part epoxy to coat the rust, and perhaps spraying it first (rattle can paint job). Anyone have any sage advice?
Steve
Re: Reworking my Tormek
Steve in my experience covering rust only stops it temporarily. Your best bet is to do your best to remove it all. Drill or dremel with wire brush works well.
Don Orr
What John says and then good old Rustoleum spray paint. It does what it says when applied as directed.
Phil Powell
Sand blast it and have it powder coated. It'll last a long time.
Jim DeLaney, Austintown, Ohio
Same problem...
I completely disassembled mine, sanded and scraped to bare metal where there was any rust or peeling, then wiped with phosphoric acid to kill the rust, dried it and put a couple coats of Rustoleum bare metal/rusty metal primer on it, then a couple coats of Rustoleum green that was close to the original Tormek color.
It's been a couple years, and so far, no new peeling paint or rust.
Josh Bowman
Steve, +1 on Rustoleum paint. I've used it for years and have had little to no problems. I put it on my boat lift 15 years ago.....I didn't even wire brush it, just slapped it on and it's held up with not problems. I don't know what's in it, but it really works well.
Josh Bowman
Steven Antonucci
Repaired for now...Stopping at the borg for paint
steven antonucci
It's a good thing I had a second stone, as I can't get the stone off of the old spindle either... I will be bodging together a crude travel Tormek out of some old parts, and I have already got my spindle and stone combo...
Ugh...
Steve
