The turners will like this one...
Bill Tindall
Read on the the end to get a sneak preview of this valuable addition to turning.
Bill Tindall
Re: The turners will like this one...
Rob Wallace
Thanks for posting this Bill!!
Great way to start April 1!
But I wouldn't put it past Lee Valley to design and market something like this!
The guy in the video is hilarious!
Rob
Betty Scarpino
I'm thinking of how I could retrofit this amazing new system for various turning tasks as well as household chores ...... oh, wait ..... I already have a vacuum cleaner .....
Very funny, thanks for posting the link!
Darn- you beat me to it Bill
And with Festool connection it will cost $1300
LOL NM
Randy Gleckler
I think a smaller model that fit in the flute of the gouge would work VERY VERY well... I never use the skew so don't need that option. :-D
robo hippy
Kind of reminds me of the hollow tube gouge some one was making a few years back that had the dust collector hose attached to the end of it. I never even thought about it, even considering my 'tool buying problem'. Heck, I could plug that one up in seconds, or less!
robo hippy
Reed A friend came over one afternoon after seeing the vacuum gouge and wanted to know if I could make one so we set up shop and built one. With dry wood it worked pretty well but you spent more time unclogging it than working with it on wet wood. It was a fun experiment.
I can use a broom and a dustpan....
Mike Stafford
Total cost about $8.....
Don in Central Illinois
If you don't use a skew, how do you open finish cans?
Shroud of Turnin...Gotta Luv LeeVlly for this one
There was a guy.......
Nick Todd
Who was marketing a sharpened HSS Tube/pipe the you could connect to your vacuum system. I never took off.
Vacuum Gouge
Don Orr
I have one and it really works great on spindle roughing.
Re: I can use a broom and a dustpan....
Terry Scott
thats fine for you to say Mike you dont make a mess
True, true.....
Mike Stafford
I guess you are right Terry. A couple of tablespoons of shavings from each box is not a lot to contend with......
I made several Vac hollowing bars ~20 years
Keith Newton
I think mine work quite well. I found the square tube worked best, because it was a lot stiffer than round, plus a lot easier to adapt the tool holder to the flat, than to a round. Vacuum looses its effectiveness under ~1" sq.
But then when you get on up to 2", the volume of air flow really kicks in, unless there is a constriction, like trying to work through a small opening, which can act like a choke on a carburetor.
Re: Vacuum Gouge
Mike Brazeau
I have a small shop vac and sometimes when roughing dry spindle pieces I just hold the nozzle in the valley of my 1 1/4" roughing gouge. Catches most of the chips and is not difficult to hold. Guess I could use duct tape if I wanted to.
