Need pen turning help
Earl
I just got a pen mandrell and I am ready to start. I measured the runout on the mandrell and it looks like 5thou. Is that ok or will I never get them right? Thanks for any and all help.
Earl
Re: Need pen turning help
Fred Holder
What pen mandrel did you get? I had never been happy with pen mandrels until I tried The Better Mandrel Saver. From Mandrel LLCE-Mail: feedback@penmandrel.com.
It does have a bit of run out if it does not screw onto your spindle all of the way to the registration shoulder. This is easily fixed by inserting washers on the spindle to allow it to butt firmly on the spindle.
This really worked well for me.
Ken Oakley-Sunny St. Cloud, FL
Go to the IAP website. it is all about pens.
.005 is plenty good
Earl
Fred I originally wanted the #2 MT Pen Mandrel Saver Package from Penn State but they were out of stock so I took the economy model. It is the one that you put in your drill chuck. I will checkout The Better Mandrel Saver you are suggesting. Thanks much.
Earl
Thanks I will give it a try
Scott Greaves
Hi Earl!
5thou is acceptable at this point. Spin it up!
I second the recommendation of visiting the IAP. Good info on pen turning! But you can always ask here as well.
What kit are you going to try first?
Scott.
Andy Lincoln,in Dearborn MI
Earl,
I became frustrated with mandrels.I had a tendency to tighten down the tailstock too hard and apply pressure to my mandrel which caused bending,warping and out of round pens parts.I have now switched most all of my pen turning to turning between centers.There are still a few kits I turn that I have not upgraded my bushings to turning between centers.
It can still be done with some conventional bushings but you have to take more care in the set up on the lathe.
There is a member on IAP that has a website penturnersproducts.com he makes very well machined bushings specifically for turning between centers.I have no affiliation other than being a happy customer.
There are many ways to turn pens.I wish I would have started with turning between centers and skipped the whole mandrel idea.
The TBC bushings are more expensive and stock is limited but I think you will find they outlast the conventional ones and create a nicer finished product.
Andy
Earl
Thanks Scott I have already turned one (slim line) with my neighbor's mandrell. His mandrell wouldn't fit my lathe so we had to rinky dink it on but I was able to turn one. I am just using any scrap wood now because I don't know how it will turn out. I have a few blanks out more special wood after I learn. Earl
