follow up on the Hunter #1 TS tool...
GaryG in MD
I promised a follow up on my recent posts. So here's the deal...
I had been having catches using the Hunter #1 tapered shoulder ("back") tool, designed by Mark St. Leger, when using it inside the hole of a hollow form (where it is designed for). I got some good advice here from John, Lyle, and others. I also spoke or emailed with both Mike and Mark. Thanks to both for that. They are very good guys.
In short, I had been keeping the tool elbow rotation angle flat (parallel with the floor) and, when working inside the HF, only pulling it straight toward me. Too catchy...
Per advice, I switched to holding the tool rotated down a bit (even though this may mean working a bit below center) and pushing before pulling. Basically that works. It's still not a walk in the park, but it works reasonably well.
I like the tool because it handles that first 1" or so right inside the hole. From there outward, I switch to a standard bent scraper.
...Gary
