best way to build a bowl kiln
paul
Howdy Guys, Ive gotten a ice box (the kind you find outside of a store) I think it has about 48 cu. ft. Whats the best way to make this into a bowl kiln?Thanks in advance Paul
Re: best way to build a bowl kiln
Steve Kubien
Keep It Simple Smart-guy *LINK*
Steve Kubien
I made my own a couple of years ago. Bare-bones and it works. The link is to where I blogged about it.
Homemade drying kiln
Alan Van Art
I've been slowly gathering the parts to build something like Ian Salisbury built in this article;
http://www.woodturningonline.com/Turning/Projects/low_cost_kiln.pdf
I have the temp and humidity controllers, but I think my implementation will be a bit different. I like the design of this tobacco kiln; http://www.seedman.com/wkiln.htm. So I may borrow some of these ideas. If you're looking for something simpler you could take a look at these;
http://wnywoodturners.com/articles/iwg/kiln.pdf
http://www.baltimoreareaturners.org/bowldryingkiln.pdf
Dan Jechura
Dan Jechura
I bought a set of plans for a dehumidifyer dryer off ebay and will build it this month. I hope it works.
Dan
robo hippy
Since a refrigerator is a dehumidifier, could it work to just put the blanks in the running fridge?
robo hippy
Rob Wallace
Re: best way to build a bowl kiln *LINK*
Rob Wallace
Have a quick read of Cindy Drozda's two-page write-up on making a low-tech bowl/wood kiln at the link below.
Rob
Cindy Drozda's Bowl Kiln Handout
Alan Van Art
In my mind, the object of a bowl kiln is to control the process, more than to speed it up. I want to prevent cracks.
Bob Macgregor
I have a small, thermostatically-controlled space heater with fan that might work for this use as a replacement for both the fan and light bulbs. Of course, CD's note suggested that simple convection worked fine without any fan or thermostatic control.
Many years ago, I had a small fridge with reversable heat cycle (intended to make defrosting simple; it worked great). I wonder if anybody still makes something like that or if a fridge could be re-plumbed to heat instead of cool?
BOB
Mike Brazeau
Bob - a space heater would have way too much energy input. I built one from a simple plywood box lined with 1" styrofoam and it will reach 40 degrees C with a 100 watt lightbulb. The early drying stages require very little heat and high humidity. A freezer or fridge is an easier solution, I just didn't have one.
Simple Kiln
joe Dickason
I'm using an old dishwasher. I lined the outside with foam for insulation. No fan. Seems to do the job. Seems like my light bulb life is short. My temp is in the 60-80 F range. Anyone have any similar feelings. Maybe I need some air movement. (?)
Skip Beardsley
I built a box about 54 inches high and 24 inches wide out of three quarter inch plywood sheathing. Inside I put 1.5 inch blue construction foam insulation and then one quarter inch plywood. Inside I mounted four metal shelves I made from closet shelf stock I bought at Lowes. On the top I drilled a three in hole through from the outside to the inside. Put a sliding door on it to control the airflow. Usually keep it about 80 percent closed.
lI have a small computer fan which I bought at Radio Shack and a single light with a 75 watt bulb. On the out side I mounted an electrical box. I purchased a 24 hour timer at the hardware store. I run a three week cycle. First the fan six hours on and six hours off for a week. The the light six on and six off. Finally both fan and light 24/7.
It will dry a soaking wet green bowl to six percent moisture in the three weeks. This size unit will dry from eight to sixteen bowls, depending on size. When the light is on 24/7 the temp get to about ninety degrees.
Skip
