Fluted Spiral
Fluted Spiral
Fluted Spiral
Starry Chan
If you were to put fluted spiral on the exterior of a bowl, would you do this before or after you complete the turning of its interior?
Starry
Re: Fluted Spiral
Re: Fluted Spiral
It depends. I have done it both ways. I will sometimes do the outside and then flute it and then do the inside. Mostly I turn both inside and outside so I know exactly what my thickness is for the flutes. It also depends on whether you are twice turning or not. When I hand carve the flutes it doesn't matter. When I use a router and index wheel the bowl has to stay round while I do the flutes. therefore I'll either twice turn the bowl so it stays round, or turn just the outside, do the flutes, then turn the inside. that way it doesn't have time to move but you do have to work fast enough to keep it from checking.
Re: Fluted Spiral
Re: Fluted Spiral
Starry Chan
John,
The bowl will be twice turned and the flute will be hand carved. I think I will finish both the inside and outside first and then carve the flutes. This way, I know that the wall will have even thickness and I just need to control the depth of the flute.
Thanks,
Starry
Re: Fluted Spiral
Re: Fluted Spiral
Works perfectly, I did one just that way about 2 months ago. It sold before I even got a photo of it.
Re: Fluted Spiral
Re: Fluted Spiral
Keith Newton
I like to turn the outside, then start the inside, but then drop back and carve the outside GREEN. Carving green wood is so much more pleasant than after it is dry, and I think a lot of people like the fact that it ends up out of round.
