info for customers at craft shows
darrin hill
got a craft show in a week or so and was gonna take some stuff. I was wondering if you guys include a note or something on how to take care of their wood purchase?
ie.. oil, usage, care of, etc?
Re: info for customers at craft shows
D. Hansen
I make my own business card and do include a suggestion about redoing wax finish with Kiwi neutral polish on the back.
Bernie Weishapl
I put a business card with instructions of how to clean and redo the finish.
Bowl care-warning: LONG
Bill Turpin in WNC mountains
Many sources,
This is what I hand out with utility bowls, that have had a polymerizing finish put on them. To keep your bowl like new: After using the bowl for food items, do not let it stand for a long time. As soon as you’re finished eating, wash it with warm soapy water, rinse well, and towel dry. To season your bowl, sometimes after sitting for a period of time, some grains of the wood may raise a little, causing some rough areas to exist. If there are some rough spots, smooth them out with #0000 steel wool. Wipe it out. Wash it with warm, soapy water, and towel dry. If it seems like it needs to be “sanded”, after washing, put in a spoon or two of salt, and be gentle: scour the inside with a paper towel, using the salt as grit to “purify” and clean the inside. Rinse, and wipe it dry.
Note: DO NOT use Mineral oil, extra-virgin olive oil, or any type of vegetable oil. This explains that Wood is better than any plastic for food items: http://www.gi.alaska.edu/ScienceForum/ASF11/1121B.html. Quote: Research scientists smeared wooden boards with about 10,000 cells of Salmonella, Listeria, and Escherichia coli, cultured bacteria. That's about 10 times the number of organisms that typically wash off a contaminated chicken carcass. Within three minutes, 99.9 percent of the bacteria were unrecoverable and presumed dead. By the next morning, the researchers couldn't recover any live bacteria from the wood. Next, the scientists upped the germ count, inoculating the boards with a million or more bacteria apiece. Then they had enough survivors to work with, but not for long. Within two hours, again 99.9 percent of the bacteria had vanished. The only thing they've found that does enhance bacteria growth is treating the wood with mineral oil.
This bowl has been finished with Mike Mahoney walnut oil and wax (www.bowlmakerinc.com). These are the best oils I have found to use. You can also use walnut oil from the grocery store. Wipe out well after use, rinse, and wash as needed. Hand wash only, do not soak. You can use mild soap, or table salt and a wedge of lemon or lime. Rinse well, and air dry or towel dry. Reapply oil as needed. Wood bowls need to breathe, so don't store in an air tight container.
To this I add, that bowls seldom need much in the way of new oil. Mike Mahoney doesn't use anything on his personal wood ware. This is especially true if the bowl is in frequent use, as the oils from the foods, are fine. If you want to re-oil your bowl, just about any oil will work. What you don't want is build up on the surface. If it starts to feel a bit gunky or gummy, that is when you use the soap, or lemon/lime and salt (cleans and disinfects). Most of the time I will just rinse, and use a plastic scrubby thing. The bowl will absorb whatever you put into it. You can't remove beet stains, bar-b-q sauce color, or blue berry stains. They add character to your bowl.
I have met some who do put their bowls in the dishwashers, but I recommend against it. Wood likes to be totally wet or dry, and does not like going back and forth. It does not like sudden changes in temperature, like going from the cool damp garage in wet Oregon winter to a spot near the wood stove.
TIPS FOR CARE:
Wood is not a stable material and is constantly moving as it gains or looses moisture with the seasons. Don’t be surprised if the bowl warps and changes shape as it ages…its part of the beauty of using natural materials…and adds to its character.
• This bowl is intended to be used….to serve salad, pasta, fruit, popcorn …you decide. After use, hand wash in warm soapy water, rinse clean and wipe dry immediately. Prolonged exposure to moisture will destroy the bowl. Never soak the bowl in water, let it sit in water or wash it in the dish washer. Do not use it in the microwave. Store upright to permit air circulation. If it seems a little rough, use half a lemon to scrub a teaspoon of salt around the bowl. It will smooth it and purify it at the same time.
Phil Stivers
Walt Bennett
Walt Bennett
After ten years of selling at these kind of shows I've settled on first making certain they're given a card with contact info. Since I don't make museum pieces, I've also gotten to the point of only using tung oil for a finish - durable, waterproof, food safe and easily repaired. This because no matter what precautions I give them (including "not dishwasher safe"), a given buyer may hand it off the next day to someone else and forget to pass the info on. The more complex the instructions (even if written down) the more likely they'll be ignored or forgotten has been my experience.
Peter Charles Fagg (UK)
I always give my customers a care leaflet outlining the basics plus a business card.
This is what I have on the leaflet:-
Care of your unique item from “Peters Platters”
Do not allow ANY fluids to contact wood surface.
Wipe clean using a barely damp cloth.
DO NOT use abrasives!
The surface has been treated with Carnauba wax.
The item is NOT dishwasher proof and if fruit is kept for any length of time the use of a piece of kitchen roll under the fruit may safeguard the finish.
A bloom may appear on the surface but can be removed by gentle polishing using a good quality furniture polish.
Keep the product away from children, it may shatter if dropped and some timbers may cause irritation.
Wood being a natural product is subject to climatic conditions. It can distort.
Central heating, damp conditions or high humidity can render the item unusable; the turner accepts no responsibility for misuse.
This does not affect your statutory rights.
Hope this is something you could possibly modify to your own needs?
Regards Peter.
Dale Jablonski
dale jablonski
I have a "care of wooden bowls" note on the reverse side of our business card.
Allen Howell
Here is what I have on the obverse of my business card. The wood and finish are changed, depending on what the bowl is.
This bowl is made from urban recovered wood.
It is Indian Rosewood – Dalbergia sissoo
It has been finished with Mahoney’s Walnut Oil and is safe for serving dry food. After use, hand wash with warm water and mild soap, then dry with soft cloth. Please do not soak it in water or put it into the dishwasher or the microwave.
Phil Stivers
Phil Stivers
The Mahoney Walnut Oil is used on Mike's salad bowls. That is not "dry". Your products are safe for food with that finish, not just dry food.
