Link Replacement Belts??
Molly Winton
Okay, I've seen these somewhere, but can't remember where. Where do I find them? My cousin has an old Craftsman (circa ~ 1930's) lathe that has an old leather drive belt. Obviously it's not viable anymore, so he's wondering where to get a replacement. Sears is no help. They say the machine is too old for them to have any data on it.
Re: Link Replacement Belts??
Dale Miner
Molly,
Leather, as in flat leather like a belt for holding up trousers?
If so, I don't think the link type belts will work. The link type belts I've seen are for V pulleys.
Here are a couple of links that may be what you are looking for.
http://www.amazon.com/Sewing-Machine-Treadle-Leather-Belting/dp/B004OQ4SUY
http://www.mcmaster.com/#leather-belts/=gr23lh
I forgot to add that to splice a flat leather belt, a taper or feather is put on each end of the belt with at least a four to one taper, six to one is better. The feather or tapered ends are glued together. I've used titebond, but think that horsehide glue is traditional.
For the round type leather belt, a small C clip piece is sometimes used to join the ends and then crimped closed instead of the feather/glue process.
Carol
This might be a challenge, but try beltsforanything.com. Nice people. Might even be able to help you out. :)
bill Crommett
I have gotten flat leather belts from a sawmill supply place. But that was years ago.
I am still running my old South Bend machine lathe with a two inch flat leather belt. If anyone wants to know how old it is I will go look up the serial number.
Scott Hurley in N VA
Check Woodcraft - they have a link belt replacement that can be adjusted to any size.
Bruce Smith
Molly just do a google search for "Belts for crown face pulleys", lots of hits . Problems, suppliers and
so on. Good luck it shouldn't be a problem finding one. We used to purchase them for machinery at
the shop but darned if I can remember the company name but if you can't locate what you require, let me know and I shall see if I can locate the name. Been retired for 8 years (fredom 55) and seems my brain has disposed of much of the shop related information that I once had....
Thanks all! Such a helpful group.
Pete in Holland
Leather flat belts ? Haven't been many leather belts made in a century. Most flat belting is a rubberized canvas type material with a metal lacing joint. Any old tractor guys in your area? They will have access to used belting, and just as importatly, the lacing machine.
You can also check the yellow pages under Power Transmission and possibly find a belting supplier (conveyor belts are similar).
Putting a v-type belt on a flat belt pulley will not allow too much horsepower to be transmitted before a belt slips.
I have old tractors and work with old machinery that has flat belts up to 10" wide. They all work fine when you know what you are doing.
Pete
Molly Winton
Thanks Pete. I think the key phrase is: "...when you know what you're doing." I'll pass all of this information on to my cousin. I'm sure he will be thankful.
Philip Morris
Molly,
I agree with previous posters that the profile of a link belt would not be compatible with the stock pulleys. I have also read that even on v-pulleys that the link belt can cause excessive wear on the older pulleys.
You may want to try searching OWWM.org (Old Wood Working Machines). These guys are really into restoring old machines, including ones with flat drive belts. This site was invaluable during my recent restoration of an old Delta lathe.
Here is a link to a quick search of their forum on flat belt suppliers.
http://www.owwm.org/viewtopic.php?f=1&t=87478&p=599436&hilit=flat+belt+supplier#p599436
Hope this helps,
Philip
Don Evans
Molly
Here is a link to Logan Lathe that made Logan and Montgomery Ward lathes (metal lathes) in early 1900's. Logan still sells parts for their lathes, hard to believe, but I have one of the Logan's my Dad bought new in 1945.
They may have a belt on site that is right length take a look.
Also some of these flat belts had metal clips that held both ends of the belt together and allow changing without pulling the spindle shaft. The clipped one's require crimping the wire teeth once it is on the machine. The convenience came at the price of having to listen to the clip clinking sound evertime it came around the pulley but better than having to pull the spindle to change it.
Hope one fits that they sell.
http://store.lathe.com/drive.html
Don
