Dye over stain
Dye over stain
Dye over stain
Ken George
I have made a cherry plaque for my soon to be born grandson. The picture area is framed with a starburst/sun. I have tried staining it with a yellow oil based stain but didn't get enough color after 3 applications. :( Can the stain be sanded off and followed with a yellow transtint or other dye?
Any advice will be appreciated.
Thanks,
Ken
Re: Dye over stain
Re: Dye over stain
Dick Coers
Most commercial stains have dye in them. Stain is usually larger particles that are meant to lodge in the pores of the wood, and dye to color the surface. I would suspect that you can add dye right on top of what you have, as long as you use alcohol to mix with the dye. Try it on a sample and see.
Re: Dye over stain
Re: Dye over stain
My experience is that you should dye first, then follow up with pigment stain. It gives a different look than when you apply pigment first. If in doubt try making some samples using the actual wood, sanded to the actual surface smoothness.
Ellis Walentine, Host
Re: Dye over stain
Re: Dye over stain
Gary Asbury
I'm a turner by hobby and club membership, but a cabinet maker and finisher by trade. We use dye all the time. If you have access to any type air-brush, mask off the area you want really yellow. A good dye product is Mohawk, or Trans Tint. Mix a small amount with vinyl sealer cut 50% with lacquer thinner and spray the area you want dyed. Once you get the intensity you like, continue with regular finishing.
Re: Dye over stain
Re: Dye over stain
Ken George
Bought TransTint Lemon yellow dye. Mixed up a sample with denatured alcohol and tried it on a sample piece. Looked good. Dipped the piece once and it was not quite dark enough. Let it dry and dipped again letting it sit for a minute or so. Looks good now. Did no sanding to remove the stain. :) This was my first use of TransTint and I am very happy with the results. Will use more in the future.
