Need airbrush recommendation
I have an old Pache dual action air brush and have to dissassemble and clean it every session and sometimes during the session. It probably just needs some new parts but I think I'm going to try and save up for a new brush. I need to call Binh Pho. I know he used to Iwata but there are so many different models I don't which one to go with.
Re: Need airbrush recommendation
Don Evans
John you are going to run into that wall that exist where each person recommends what they have, because probably no one, maybe one or two only have used more than one brand.
I have the dual Pasche and like it as I have the one that allows setting the paint flow both variable and set amount.
But I am a bit confused in that you say you are doing this because you have to clean it after each session or switching paint? That is normal with any brush used, brand isn't going to change that. these things are atomizing the paint and they gotta be clean to do that.
Don
Don Evans
forgot to add I've got all 3 needles with mine, that is a real bonus when working with different things.
Don I clean it constantly but it seems to get to where the needle will jam up and won't move. Perhaps I'm not assembling it correctly although I've read the manual many times and had it apart many times. Maybe I don't have the correct cleaner but I did buy the same brand as the paints.
Yesterday I was just using water based dyes that I would think would never make it jam up. You only have to clean it to get rid of the residual color which I did after every color.
Randy Gleckler
John,
Bring it to the next Crossville meeting and I'll look at it. Been getting a lot of training on airbrush's lately.
I got to try the GREX airbrush when i was at the Loveland Symposium in sept and REALLY liked it. Thought I had more control than either of the Pache air brushes I have or the badger. I know a LOT of people recommend the Iwata too, but that's just what I've experienced.
I'll let you know on one of the Iwata's before too long, My wife just bought one, but I'm only allowed to use the food coloring paints in it, since she uses it for her cake decorating ;-)
Jim DeLaney, Austintown, Ohio
Re: Need airbrush recommendation *LINK*
I have Badger, Paasche, and Iwata airbrushes, and have come to prefer the Iwatas- "Eclipse" brushes over the others.
If your Paasche is clogging repeatedly even after cleaning the needle, I'd suspect you have some gunk (technical term) in the needle seat, which will require removing the entire tip assembly and soaking it for a while in airbrush cleaning solution, then carefully cleaning away any residue with Q-tips.
BTW, Blick Art Supply sells a very good airbrush cleaner. I use it by spraying a few drops of it between colors, and also for more thorough cleaning when I disassemble the guns. I also use the airbrush cleaner for a final cleaner in my HVLP gun.
Here's a link to some cleaning tips:
Airbrush needle cleaning
Dick Coers
Binh only has one on his web site. The hi line ch model h4100. His price is only a dollar higher than Amazon.
Binh Pho
Tommy Holmes
This is the one I got at Binh's recommendation. One thing that sets it apart from many airbrushes is that it has a mac valve which is a small valve near the tip of the airbrush that gives you air control directly at the tip of your nozzle.
steve worcester
I have 4 Iwatas and love them. You can go bonkers looking at specs, but a good source is coast airbrush
The one Binh sells is a great brush, but a lot has to do with what you want to do with it. They generally are made for different line widths and levels of detail. An HP-CR (Revolution series) or the HP-CS (Eclipse series) are some of the good, lower priced all purpose brushes. If you want detail, spraying thin materials, go with a .20 or .35 nozzle/needle combo, more general, medium detail and lines to a wider pattern, go with a .5. Some brushes allow conversions from one to the other. If you are going to spray solvent based product, get one with a teflon seal in it.
The HP-CH he sells is a great brush, and there is a definite difference in the spray quality between products, but mostly down to their ability for detail.
Rob Wallace
Rob Wallace
John:
I was about to suggest that you contact both Steve Worcester and David Nittman who are also somewhat airbrush gurus, as is Binh Pho. Looks like Steve beat me to it, so here's a link to David's web site (below).
I just use a dual action Paasche, and it works for me, but I really don't do a lot of airbrushing.....
Rob
David Nittman - take 'Airbrush on Wood' Link
dick gerard
I have an Iwata eclipse series BCS siphoe feed plus the new Grex, plus a couple I started with from Harbor Freight. I have learned to favor the gravity feed above the siphone feed, so I will selling my Iwata soon aling with a couple dozen siphon feed bottles. I'll replace it with a gravity feed Iwata Eclipse or another Grex. I really like the Grex a lot!
Just my 5 cents worth (everything else is going up, so 2 cents just doesn't make the grade anymore).
Dale Cook
Hi John , I just bought this one as it was recommended by a couple of friends that do a-lot of airbrushing. They said it was very versatile and the price was right. http://www.artistsupplysource.com/product.php?productid=16585&cat=368&path=alt&page=1
Dale Cook
Hi again It's a Pasch V with 2 tips for 70$
Thanks for all the advice
steve worcester
In all of this, what we didn't say was what not to buy.
Don't buy an off brand airbrush. It is inevitable you will need part, needles bend (and are basically junk after that) nozzles get irreparably clogged, weird size and incompatible hoses infuriate me.
So, Iwata, Grex, Badger, Paasche, all are fairly easy to get parts for. If you have a Hobby Lobby in your area, they sell the "lower" end Iwatas and have coupons in the paper all the time.
John Scheideman
John-
I bought a Grex two years ago and like it alot. It has a single pull trigger rather than the sliding trigger on top. I haven't had any trouble with it so far.
John
Jim Evans
Jim Evans
What is the difference between internal mix vs external mix?
Jim Evans
Jim Evans
Well, I went ahead and bought a low end Iwata NEO at Hobby Lobby. $60 - 40% discount = $36 for my first air brush.
I didn't have Hobby Lobby discount coupon, but by going to Hobbylobby .com on my phone they accept the coupon from the web site. I like this because their published discount page did not cover the air brush. The phone coupon is good for 40% off anything in the store.
steve worcester
Makes a big difference in the atomization. But an external mix can usually spray a thicker material that you otherwise couldn't get through an internal mix nozzle. You will get a finer mix with internal.
Jim Evans
Jim Evans
Thanks, I found out that all Iwata's are internal mix.
