Veritas - Innovation in Tools
So I had this tree cut down ...
kellyanderson72
now what do I do?
I believe that this is an Elm tree that was growing in my back yard untill yesterday. I would like to cut it up for turning but I have no idea where to start. It is about 24" across at the bottem and about 21" where it starts to branch at about 6 1/2 feet.
I am new to turning and figured that this would be a good way to get some free wood to practice with, it even has a couple of burls on it, but am not sure where or how to start cutting to get some good blanks.
I appreciate any advice or direction to a good web site or book that might help.
Thanks
Re: So I had this tree cut down ...
Brad Vietje
See Handling Green Wood, Below...
Re: See Handling Green Wood, Below...
K Anderson
I just did plus a couple more, Thanks
Brad Vietje
Brad Vietje
Hey Kelly,
I didn't have much time last night, but that's a very nice treasure trove of turning wood you've got there! Elm can be great to turn, and Elm burls are quite rare around here -- great score!
Fresh cut healthy Elm can be very strong, tough wood, but it is not at all rot resistant. Be careful if you see signs of spalting. American Elm seems to spalt in two ways (maybe more?), that I call white rot and black line spalting. If you see white flecks and softer lighter colored areas, be careful about splits and weak areas -- especially if there are white lines along growth rings. I've had a few Elm platters fly apart with this sort of decay in it. You can test any thin slices you cut off the blanks to see how they break to get a sense of how strong the wood is. The other way it tends to spalt -- possibly from a fungus that enters the logs/billets/blanks after being cut up if seasoned outside -- is with black staining which can also be along the growth rings. This can be quite attractive, and doesn't seem to weaken the wood structure as much as the white rot.
Fresh Elm has an OK-at-best smell, which gets considerably worse as the wood sits around in the log form. Spalted Elm can smell pretty bad, and you'd be wise to protect your lungs, too.
Good luck, and have fun with all that wood.
Safe spinning,
Brad Vietje
Newbury, VT
charlie belden
Before getting out the chainsaw, find some side walk chalk - and a METAL DETECTOR. House Trees are notorious for containing nails, staples, bolts. bullets and all sort of other metals and someotimes even rocks- especially in the bottom 7 to 8 feet. And if they've been in the tree for very long, the tree can be sneeky and hide them under layers of bark and maybe even wood.
A very experienced sawyer destroyed a fairly expensive large circular saw blade - cutting into a 1" diameter piece of All-Thread hidden 8" inside the log he was sawing - even though he had my White metal detector, which would have found it before he turned on the saw. He LOOKED for evidence of metal - but the All Thread was impossible to see - with your eyes. Metal detectors are sort of like having X-ray vision.
Buy, beg, borrow or steal (ok so I won't advocate stealing) a metal detector. If it finds something, mark the area with the sidewalk chalk and check all the way round the log in the viciinity because sometimes that metal may go half or all the way through the trunk.
Wood dulls cutting edges. Metal DESTROYS them - and may require changing one's drawers ; )
Lewis Dodd
I was turning a vase once and discovered some aluminum wire in the wood, the wood completely enclosed it. It polished up real nice and made a very unique piece, got captured by a family member. It actually enhanced the piece
