Fire Possibility Question
Tom Minehan
I normally turn dry wood and my dust collector bags contain dry material from turning, sanding, floor sweepings etc. Today I was roughing some bowls from fresh cut, very wet maple. I was concerned that mixing this wet material with the dry stuff already in the collector bags may cause a spontaneous combustion fire. Should this be a concern? I did not collect the wet stuff in my dust collector.
Re: Fire Possibility Question
I'm certainly not an expert on that but I don't believe so. Green wood drying doesn't produce any heat that I know of. Now if you sucked up an oily rag watch out.
Wayne Kuhn
I don't suck them up with my DC or shop vac. They get scooped up, put in a trash can with a liner (specifically for that purpose.) When full it gets dumped in the compost pile. Green wood shavings will fill your DC in no time flat.
Wayne
Brad Vietje
Along those lines...
Brad Vietje
Dust collectors are for sucking up and filtering dust. They are not intended to be used as a shop vac, though many woodworkers use them that way.
Green wood makes almost no dust, nor does wet sanding of green wood. I would agree that sweeping, scooping or shoveling up wood shavings will give you a lot more life out of your dust collector. Wood shavings can be composted if you are a gardener, or used for landscaping. If you bag 'em up, you can sell them to people who will want them.
Just one fella's 2 cents, and worth exactly what you paid for it ;)
Safe spinning,
Brad Vietje
Newbury, VT
Dale Jablonski
dale jablonski
I have a plastic trash bag underneath my lathe that catches alot of the turning chips I create...dry and wet. The remainder get shop vac'd up and put into a trash can that goes into our composter along with the other chips from the collection bag beneath the lathe. While the composted material gets warm during the summer (over 100 degrees) I don't think you would have a concern about spontenous combustion. If you do, when your bag gets full, make sure it's outside where the cooler temperatures, especially at night, will reduce the potential even more.
Re: Along those lines...
bill Crommett
I have eliminated that problem. Because I altered the intake on my dust collector, I could no longer keep the upper bag on the frame, it kept blowing off.
So I cut a hole in the shed where the dust collector lives and now everything is blown outside - including the rare piece of sandpaper. The force of the outlet stream is such that the shavings and dust are dispersed over a large enough area that it seldom accumulates any depth.
mold yes, fire no.....
Dick Coers
No way that wet and dry wood can get up to combustion temps. I found a site that said it takes over 500 degrees for wood to auto ignite (temp it ignites without a fire or spark present).
I use a leaf rake to gather the shavings on the floor. Works better than a broom and reaches around lathe legs and rollers on my cabinets. That and a snow shovel will get most of the shavings.(If you have a show shovel and your not a turner you live too far north) Then I use the dust collector and broom to get the rest.
(Message Deleted by Poster)
robo hippy
Composting materials can generate enough heat to ignite. If you drive past the garden recycling centers and look, there is always steam coming off the piles, and they make sure to turn the compost over regularly to keep fire problems down. These are mountains of compost. I doubt that the shavings in a dust collector would have the mass to generate that kind of heat, and you would have a seriously over loaded bag before that could happen.
robo hippy
mjonesrdg
Wood chips and dust by themselves in the bag pose little threat of spontaneous combustion. Wood barely browns at 350 deg. and the organisms that create the heat in decomposition are killed off by temps exceeding 212 deg. Effective composting requires nitrogen, moisture, and oxygen, in addition to the carbohydrate medium.
bill Crommett
John: I brought a snow shovel with me when I moved down from Michigan.
I have used it four times in the last twenty years.
Re:Fire, yes, if conditions are right
Dick Coers
I guess if you consider a dust collector bag to be a "mountain of chips", and you throw some water into your dust collector to simulate rain to keep it damp for weeks at a time, I agree, you might get a fire.
Wally Dickerman in Arizona
Most wood shops, pro or amateur have a dust collector. Has anybody ever heard of a fire being started in one?
Composting experiment
Doc Green
Many years ago I tried composting sawdust mixed with dry oak leaves. I layered up a pile perhaps 5' diameter and 4' high, added enough water to get it "properly moist" and then sat back and watched. And watched. And watched.
In short, nothing happened. I had a lab thermometer on a stick I could insert into the center of the pile to measure the temperature. It didn't even get warm.
On the other hand, a similar pile made up with a lot of green plant matter did get hot, up to 160 F at one point. My conclusion is that sawdust by itself, either green, wet, or dry, is not a risk unless you have a huge pile, perhaps as big as a house. My experience, FWIW. ~Doc
Doc, Alligators do that to incubate the nest.
Keith Newton
The green vegetation generates heat, and there is a certain temp that determines whether they are either all males, or all females.
Brad Vietje
So THAT's Why We Have No Female Aligators in VT...
Brad Vietje
...our compost must not be hot enough! :b
Safe spinning,
Brad Vietje
Newbury, VT
Mike Stafford
Re: So THAT's Why We Have No Female Aligators in V
Mike Stafford
Yeah, among other reasons that is why you don't have female alligators in Vermont. Still gotta be on the lookout for male alligators though..... :b :D
