Steven Antonucci -Help Please!
Ricc Havens
Steven, Would you have some info or tips on the best way to replace a belt on an older Nova 3000?
Thanks
Ricc Havens
rv.havens AT gmail.com
Ricc Havens
Thanks
Ricc Havens
Re: Steven Antonucci -Help Please!
Replacing the belt should be easy. First release the belt tension of course. If you can't just work it around the pulleys and get it off, take off the outside red pulley guard. Then you should easily be able to get the belt off.
you also need to remove the handwheel
steven antonucci
if it has one. It is reverse threaded, so you can lock the spindle and use the knockout bar to remove it.
As John said, it's not that hard. Unlock the tension and pull it forward to slack the belt. It has clearance on either side, so it should come right out.
If it isn't post a picture and I'll see if your lathe is different than mine.
Steve
THANKS GUYS - BELT REPLACED --NM
