OK folks, what is your solution to dealing with pesky end grain on bowls or turnings? I have been scratching my head and have several suggestions from friends on turning some semi green pecan. No matter how sharp the tool, "plucking Is still occurring.. 40 grit don't help neither!
Do you usually have end-grain troubles? Good technique with tools ? Are you trying to cut the end grain, or scraping/shear scraping? My angle here is that a very sharp cutting tool used with more of a scraping angle may still pull out fibers.
Sometimes it helps to harden the wood, or lubricate it with soapy water or paste wax. Some people brush on some thinned lacquer or shellac to hold the fibers together better. For small items, CA might be helpful.
If this semi-dry Pecan is giving you troubles that you wouldn't usually have, consider tossing the wood, and substituting other pieces of wood, or maybe roughing it out, and drying it more completely. I find that green wood cuts well, and dry wood cuts well (with more effort and dust), but in-between is usually worse than either extreme.
Ha! Thanks Mike!! After today, I started looking at some old floor sanding paper when I redid my oak floors in the house. What is that, 000, grit the size of small broken rocks and pebbles!! I have it getting acquainted with some sand and sealer.....sure wanted to finish the job today, the wood just wanted more attention I guess! But, tomorrow is another day!!!
Watch John Lucas' video on rubbing the bevel on Hunter tool. Are you using a scraper or bowl gouge? Try a negative rake scraper. Also try dampening the surface with water just before a light cut. Sharp tools, light cuts.
Without watching you turn, it would be impossible to suggest why you are getting "plucking", but I suspect that it could be corrected at the lathe.
In the case where I have worked with some people whose turning work needed a quick fix, I have shown them how to use a gooseneck cabinet scraper to first remove the plucked end grain and then blend it seamlesly into the rest of the bowl. Much faster than paper, and better results. It is done with the bowl in your lap, and not on the lathe...
I agree with Steve. Last ditch effort is to use a cabinet scraper, with the lathe off of course. It works wonders for getting rid or tearout.
Usually when I have fibers that won't cut I go to a tool that has a sharper cutting angle. Same goes for tearout. Quite often speeding up the lathe and trying not to force the cut will help.
For fibers that won't cut I'll also try a lubricant like paste wax.
For tearout I will try paste wax and a sharper tool. If that doesn't work I try soaking it with thinned lacquer. That also works for fibers that won't cut clean. If that doesn't work I try thin CA.
Usually one of the above works. I did have a piece of walnut the other day that simply would not cut clean when it was green. I force dryed the surface with a hair dryer and manged to get it cut.
Lewis, A few questions, before I offer some comments or suggestions...First of all, I'm not familiar with the term "plucking", since it's on endgrain. Would I be correct in assuming you are referring to "torn grain"? The next question is: What angle is the bevel ground on your gouge?
Get yourself a Kelton Multi-Axis Scraper. Put a nice burr on it, set it for a shear cut with a slight negative rake. Light cuts. Solved my problems with pesky wood.
