Wax-oil sanding
Wax-oil sanding
Wax-oil sanding
Jim H
When using bees wax mineral oil mix for sanding, what is the best solvent to wipe down with between grits and before finishing?
Re: Wax-oil sanding
Rob Wallace
Mineral Spirits.
Re: Wax-oil sanding
Thank you!
Re: Wax-oil sanding
Re: Wax-oil sanding, bad plan!
mjonesrdg
My personal experience is that any wet sanding on bare wood will tend to dull the color and diminish grain contrasts. To better visualize the effect, imagine that the summer wood is white and the winter wood is black....wet sand this and you get a slurry of some shade of gray...that you are rubbing into the wood! Wipe it with solvent, and you will get some of the gray off, but not all. Some of it will migrate into the pores of the wood, and some wood will stain with it's own sanding residue. Unless you intend to pressure wash with the solvent, you will lose some of the "pop" of grain that we all like to accent.
Mike Jones in Redding, Ca.
Re: Wax-oil sanding
Jim H
So is it the wax or wax-oil combo? I like the idea of less dust and the lubrication, but not sure of the trade off.
Re: Wax-oil sanding
Mike Stafford
Mike Stafford
I frequently sand exotics with wax and clean between grits with mineral spirits. It has been my experience that the wax ends up collecting the sanding grime and is easily removed when you clean with the solvent.
I have sanded tulipwood, cocobolo, black and white ebony, ziricote and a large number of other rosewoods without any ill effects on the finish or in the clarity of the grain. Below are a couple of pictures of a tulipwood box recently described in Woodturning Design. It was sanded inside and out with paste wax.
Softer woods should not require a lubricant during sanding unless you wish to keep down the sanding dust. In that case you can sand with water.
Re: Wax-oil sanding
Jim H
Thanks Mike. I have had the Bees wax and mineral oil for awhile meaning to make up a mix that I had seen recommended somewhere. I just had not thought of using a solvent to wipe between grits until your excellent article. So far I have made some real cool dust and chips, a couple of so-so boxes and three pens that came out fairly well.
Boxes are the main thing I'm interested in right now. Time in the shop has been real hard to come by. Thanks for the advice.
Re: Wax-oil sanding
Brad Vietje
Brad Vietje
On open pore woods like White Ash or Oak, the darker "slush" can fill the pores, and if you're careful when cleaning the surface with mineral spirits, you can either preserve that for contrast, or with a lot more effort, clean the pores out, too. I like the subtle patinating affect on relatively dull woods like Ash, and I've had pretty good results with lubricated sanding on these woods, as well as hard exotics like Mike reports. I also think the lubrication helps avoid overheating and heat checks when sanding really hard end grain of some exotics.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Wax-oil sanding
Jim H
Thanks Brad. As stated, I'm still very inexperienced, but love WC for the knowledge that is so freely shared.
