Reciprocating Carving tool
Jorge
Have a few projects in mind that could use a reciprocating carver
Which one is your favorite?
Can a Foredom SR reciprocate? There is one locally available if I want to try it before buying it, but the person does not know anything about it and there is no manual.
Thank you!
Jorge
Re: Reciprocating Carving tool
Don Evans
The answer is yes it can, the recip action is all done in the handpiece that you attach to the flex shaft. The SR is just the motor.
There are several rotary tools available that have the handpiece that recips, I've got a MasterCarver that I like a lot better than a Foredom. Biggest problem with Foredom is their over pricing their stuff.
Do a google search for Master Carver and check the price on it, you can find it with a package deal that includes 3 handpieces and one of them is the recip one. You'll find that it is less expensive than the Foredom. Also, any Foredom handpiece will work with the Master as they both use the same type flex shaft. Also, the Master is more horse power than the SR which I believe is 1/6 hp the Master is 1/3 hp and they just came out with one that is stronger at 1/2 hp. It's built like a tank also.
Don
John Jordan
The Foredom reciprocating handpiece is a POS. I bought one figuring with that nice motor, it would do some of my heavier carving and save my Automachs some wear and tear. I used it five minutes and sold the whole mess. :D
If you buy an Automach, you'll never regret it. I'm on my third one in the last 25 years. If I wear the current one out, I'll buy another.
John
I've had 2 different people tell me the foredom was not worth it and the Weecher was better but mostly because the flex shaft was thinner and more flexible. I don't really know how well the handpiece works but they seemed to like it. I looked online and it seems that by the time you buy the handpiece and flex shaft your up to about half the price of the Automac. I have only heard great things about that tool.
I have one of the discontinued Ryobi's. It's not great but is getting me by for now. I'm saving for the Automac. Most of my carving lately has been by hand or with rotary tools.
Randy Gleckler
Just was using the Weecheer setup tonight. Can't say I have much experience with anything else.. but with the Flexcut chisel in the hand piece it worked very very well for me. I can't see me using it as much as say John would, but it worked well for what I needed on this project and maybe a few others...
Jorge
Thanks Don, the price is attractive for sure.
Jorge
John,
I like this best, the tool with no flex shaft to deal with is great.
I am saving for this one.
Thanks!
Jorge
John, Randy,
Thanks for the input, I am saving for the Automach.
Jorge,
I use a Mastercarver recipro handpiece on my Foredom CC and it does well for small carvings. If, however, you have any history of carpal-tunnel, the vibration will limit the length of time you can go without aggravation. I also reshaped the Flex-cut blades I use to put convex bevels on them for better control. You will also do well to keep the bevels polished and the edges nick-free unless you plan on doing a lot of detail sanding. :\
m
kruizen
check out smoky mountain woodcarvers, they have refurbished automach recip carvers for around $150.00. I have one and it works well.
the website is http://www.woodcarvers.com
Jorge
Mark,
For my age I am doing pretty good about hand problems, but they are there, I do better on bigger projects, my hands do not do well with little stuff.
I'll keep your advice and keep the chisels sharp.
Gracias!
Jorge
kruizen,
That is a very good piece of info, thank you!
Carole Valentine
My Weecheer has stood me well, although I use my Ryobi more for recip carving, but they don't make the Ryobi anymore. At John J's suggestion I took the spring out of the WeeCheer recip handpiece...much better. My WeCheer is an older heavy duty model with pretty good power (1/3). Foredom was, in my opinion, way to pricey for what you get. Would love to try an Automach.
Keith Newton
Automach gets my endorsement also. I started off with one of the little light-weight brands, which wore out in one day of moderate use.
I recently ground a new straight cutter after the straight flexcut broke at the shank. Made it out of a .25 x .25 x 2.5" tool steel. It really works great for squaring up the corners of router mortises.
Thanks everybody!!
Jorge
Thanks Carole,
Keith, I could use that bit last week, made a coffee table. Thanks for the endorsement, I'll jump to the re-built ones that kruizen told me about.
John Jordan
Good tip. They keep a complete line of parts, and have lots of other stuff, too. Sometimes I take my Arrowmont classes on a field trip to visit Smokey Mountain Carvers. :)
John
Re: Thanks everybody!!
Keith Newton
That sounds like a good deal to me. I sent mine to them for a fix, and it was good as new. Keep grease in the little cam compartment, and don't use excessive force, and you will love this tool, especially on green wood.
Jorge
Good tip,
thank you Keith.
Jorge
Someday I hope to make it to Arrowmont...
John Jordan
Jorge, You would never regret it. Big fun! :)
John
Bob Moffett
Bob Moffett
I do quite a bit of carving in making bowls and hollow forms with spirals on the outside. I use an Arbortek reciprical carver and love it. Although it is loud when you are right on it, it is fast and stronger than most anything out there. It is a quality tool meant to do a lot of work. No affiliation, just a very satisfied customer.
