Drying bowls in a paper bag
Dan Jechura Temperance Mich.
I've just started to try out drying ruff turned bowls in a paper bag. My question is can you put more than one bowl in a bag?
Dan Jechura
Temperance, mi.
Re: Drying bowls in a paper bag
Jason Clark
I do. I figure that they slow down the drying process, as the moisture evaporates from one bowl it is partially reabsorbed by one of the other bowls. It also makes keeping track of nested sets easier as they all usually end up in the same bag.
Jason
I do the same but sometimes use boxes. I don't close the lids very tight so air can pass but the box seems to slow down the air movement.
Bill Howatt
Yes, I often use the large garden waste bags with several bowls in them.
When you get a lot of wet wood in one place with minimum air circulation you should monitor them for the first few weeks when the moisture content is high in case black mold starts to grow.
Sometimes I wrap them in newspaper for the first week or so and change the paper when it is damp which at first can be every day or two. Then when I think the "excess" moisture is out I place them in the bag. I have had more grief from black mold than cracking which is why I now do this.
Bill
K Anderson
Do you just wrap them in the paper and put them on a shelf or do you puth them in a bag too untill the paper stops getting wet?
I'm with him.
Bob Edwards
Like john I use a card board box. However I also use dry wood shavings. I put my floor sweepings in the sun to dry than fill two boxes with the shavings. I usually rough more than one bowl at a time and loosely pack as many as will comfortably fit in one of the boxes. After three weeks or so I transfer them to the second box of dry shavings and put the wet ones in the sun to dry. You need to know I live in south Texas so sunshine is seldom a problem.
Steven Antonucci
If the bag is big enough
Re: If the bag is big enough
walta
If the bowls nest you can get some nasty mold gowing in the void that may stain the bowls.
Walta
No Bag at all
Jorge
Dan,
I've used many methods of drying and settle on no bags at all, just leave my rough blanks in quiet areas of the shop, away from heat and air currents, when I run out of storage space, I do nest the roughed bowls with 3 sticks between them so air and moisture have a way out. One a week or so i look at them and see how they are doing and when they feel like they are dried, I start weighting them and keep a piece of tape with the date and the weight, something like every 3 weeks, when they weight the same as last time, I call them done and they go to the finish queue.
There are some that will crack, and they will do it no matter what method you use, so save energy, the "dolce far niente" works for me.
Re: No Bag at all
Jason Clark
Leaving anything unsealed, unbagged, or unboxed out here in AZ is a recipe for disaster. Surface cracks can appear within an hour.
Jason
Skip Beardsley
No matter which way to do this I strongly suggest you use end grain sealer or latex paint to seal the end grain. Until I built the kiln I used double bags and let them sit for two to three months. Not lots one yet using this method. But I do seal any blanks I am going to store.
Skip
Brad Vietje
Brad Vietje
Skip,
I think this depends a lot on your location, and the wood species used. In a really dry, mountain climate, end grain sealer might be needed almost all the time. Where I am (Vermont) a paper bag or like John says a cardboard box works real well.
Wally turns green wood in Arizona, and smears 'em with paste wax, which I've done many times with no significant failures. I rub it on while they are spinning on the lathe.
The danger in putting multiple bowls in a bag is that you could get mold or fungal growths on them, and they can get slimy if you live where it's relatively damp. I tried using wood shavings in the bag or box years ago, but that's a guaranteed slimy mess where I live, and I don't recommend it o anyone.
I use one bag per bowl for larger ones, 6-8 small bowls in a cardboard box, and I routinely use Anchorseal only for high-value or irreplaceable bowls, or wood that's known to move a great deal (like Apple or Beech). In my climate, putting bowl rough-outs in paper bags or boxes has an almost 100% success rate. I also bevel all the edges slightly, and pay attention to the wall thickness.
Safe spinning,
Brad Vietje
Newbury, VT
Bill Howatt
Usually in a bag or a box but I usually don't close the top up tight while the paper is in use. In most cases my roughed bowls don't get put on the shelf until they are dry.
I don't think there is a single method for drying, they all work and given your storage area's environmental conditions some may be a bit more successful than others. The main idea is to slow down drying so the wood can slowly move as the water-laden cells collapse and on the other side of the coin to avoid undesired mold growth. Another factor is to have a wall size that is not too thick and is fairly uniform and then there is also the tree's history of built-up stresses and its species which also determine its liklihood of cracking.
Bill
Skip Beardsley
You are correct in pointing out that location should always be considered when answering questions here. Non more so than drying bowls. Here in the mountain west using sealer has cut the checking issue to nil. Thanks for the reminder.
Skip
Re: Drying bowls in a paper bag  " Thank You"
I wish to thank every one for their sugestions. It gives me food to think about. I think I am going to try the sealed no bag and the sealed boxed. I am already doing the sealed in a bag. I already know about the no sealed and no bag, I get cracks.
Dan
Good post Brad
Keith Newton
You know here on the net, someone in the desert somewhere can be giving advice to another in a rainforest about what has worked for them. Unless you know all the aspects of a situation, it is hard to separate the good from the bad advice.
Back when I was doing lots of turning, and the conditions were right for fast drying, I would bag them, then take them up to the loft where I sleep. I am a light sleeper, and could hear the first hints of checking amplified through the bag. A spritz from a sprayer, or second bag will slow it down. I have never felt the need for chips here in Arkansas.
There is just so much crap out there, that the novice isn't equipped to comprehend, without offending some expert somewhere. When it all boils down to not letting the quick dry endgrain-zones dry out faster than the thicker-interior, across-grain zones.
Dan *LINK*
Dave Peebles Lyons, Ohio
This is a little off topic, but we have a woodturners club in Blissfield Mich. that is meeting tomorrow from 1pm to 4pm.
I will not be able to make it tomorrow, but if you can you could be welcomed with open arms. link below.
If you have already been there and I missed meeting you... please disregard. :)
Best wishes,
Dave
Mi/Oh Woodturners
Dan Jechura
Re: Dan
dan jechura
Dave
Please send me your email so we can talk.
Dan
redpacecar@buckeye-express.com
