Stuck my fingers in a wing'ed piece
Not once but twice, so I decided to take a break for a few minutes. Took a couple of days off of work during spring break so I'm working on a new style of handle for a mirror I'm working on. It has parts that are what I call paddle turning. That is, a flat board turned as a spindle which in this case leaves wings flying around. While turning the beads on the main shaft of the handle I stuck my finger in the upper wing. Said a few kind words to the spindle and then finished the turning.
Then when I was sanding, did it again, said something that resembles "boy this is fun" but in a courser language. finished up and decided to let my fingers cools down. I think my left index finger has stopped throbbing now.
On the plus side I'm planning a bead turning video. Turning 30 some beads on a handle with a spindle gouge really helped me understand how to teach that.
About rested now so back to the offcenter turning to finish up the handle.
Re: Stuck my fingers in a wing'ed piece
Stop Doing That.
"...twice, 'shame on me'."  ;-)
but it was so much fun
Bernie Weishapl
OUCH not once but twice.
Twice
So, John, you didn't believe you did it so you did it again just to make sure you did it the first time?
Feel better and rejoice you weren't gluing fingers back on. ;)
Joe Bradshaw
Re: Twice
Joe Bradshaw
Double the pleasure, double the fun.
Dick Hines
Dick Hines
Man, I sure am glad I am not the only one who has done that.
Since I turn a lot of square forms,.....
JamieDonaldson
....I have learned to keep an ice pack ready in the freezer! :b
Mike Stafford
You keep doing that and you'll draw.....
Mike Stafford
back a nub or nubs..... :b
Carole Valentine
Now John, what on earth did you do that for - and twice even!!! :D Anything with wings on it definitely keeps my attention. I've only done it once...so far. :\
Didn't do it anymore today
Must have learned my lesson. Although the later off center turnings were much more dangerous because it only had one invisible wing flying around. I think that is scary enough that you really avoid it.
Re: Wings and fingers
Bruce Pratt
I put pieces of tape on the corner/edge/end of the wing so it sticks out a bit on both sides. When my fingers approach the wing, I can feel the tape before the wood. (Not my original idea; saw it on a show where Stuart Batty was doing a winged bowl).
Brad Vietje
Thought I Broke My Arm...
Brad Vietje
Man, I hear ya, John!
I thought I'd broken my arm when I was whacked in the arm with a corner of a pretty big square-edged crotch bowl at about 800 RPM a few months ago. Some ice slid off the roof and made a loud sound that I turned to see, and my left elbow wandered just a bit too far to the left, and THUNK! I got nailed just below the elbow joint so hard it tore a chunk of skin off and gave me quite a bruise right through my Carhartt quilted jacket. I also dropped the gouge on the concrete and had to re-grind it a few days later when I could hold it again.
Ultimately no breaks, just bad words and a few very sore days. Bad end to what had been a very productive evening, having completed two other projects beforehand. Those spinning wings are dangerous, and a project for a well-rested body and an alert mind. I should not have been working on something like that at 10 PM.
That bowl is still air drying on the floor beneath the headstock. I'll have to conquer it one of these days when it gets a bit warmer. I'll be well rested the next time...
Safe spinning,
Brad Vietje
Newbury, VT
I'm thinking about a lexan guard
This was an odd project the pieces weren't sticking out very far so minor hurt was all they did. However I'm going to start on some single piece mirrors that will have a handle sticking out 8 to 10" from the 5 1/2" mirror body. You can't even see that when it swings past.
I'm toying with building a plexiglass guard that goes around the chuck and sticks out slightly further than the largest mirror I plan to build. It won't stop you from hitting the handle if you stick your hand in there but since it will be a solid disc right behind the handle it will be very easy to see so I think your chances would be greatly reduced. I would use colored plexi so I could see it easier.
Danger!
John,
You used 2 words that are mutually exclusive; "Lexan" and "plexi". Readers should know they are not the same and are not interchangeable in your proposed application. Lexan, a polycarbonate thermoplastic material is far tougher and will not shatter under normal use conditions. Plexi[glass] is an acrylic material that is more brittle and can easily fracture on impact sending sharp shards flying. Lexan will work for what you propose; plexi will NOT.
m
Ken Oakley-Sunny St. Cloud, FL
my grandfather told me as a young boy, one of the rules of life is to never put your finger where you wouldn't put your tongue.
Guess that rules out working on the car
Re: I'm thinking about a lexan guard
Ralph Watts
John,
Every once in a while I turn a dipper. They have the same characteristic as your mirrors. A spinning handle. Your idea of mounting something on the chuck got me thinking. Maybe something a little like a tool rest base from wood and secured to the ways would be a workable solution. The whole thing could be made from plywood and a slot for the chuck, or work, would allow you to completely cover the spinning handle.
Maybe a slot with the opening away from where you are standing or perhaps just a cover on the turner's side of the chuck would also work.
Thoughts?
Best regards, Ralph
