turned 6 bowls tonight
An artist friend stopped by last night. He needed 6 -3" diameter bowls exactly alike that were half circles. I turned them this afternoon. He's going to paint them. The inside was left straight off the Hunter #4 tool. The outside was shaped with a bowl gouge, cleaned up with the Jordan shear scraper and then sanded with 220 grit. I filled the worm holes with wood putty.
Re: turned 6 bowls tonight
john lopez
Nice work...
What tools or devices do you use to get a series of pieces uniform ?
I'm curious to see a finished piece by the artist.
Is it a collaboration or gouge ninja project ?
John I cut out a cardboard templates, test fitted, see what needs to change and cut there. Repeat as often as necessary. I used the vacuum chuck to turn the outside since it didn't have a foot.
nice job, John...
GaryG in MD
What's the wood? Are they dry? ...Gary
Hickory-bone dry
It turned surprisingly easy with my tool really sharp. I used the Thompson 3/8" V gouge for all roughing and hollowing. I did the final shaping of the inside with a Hunter #4 which left it clean enough I didn't sand it. The outside final shape was done with the Henry Taylor 3/8" gouge sharped to Stewart Batty 45 degree grind.
Randy Gleckler
Nice work John, I was starting to wonder if you only did Demo's and work anymore you've been so busy. Glad you got some time to turn..
Bernie Weishapl
Really nice looking bowls John.
very nice...
GaryG in MD
I love the grain patterns and the shapes.
I have those exact same tools, right down to the branding, except I have the Hunter #3 and #5. I have my DT 3/8 spindle gouge sharpened � la Cindy or Hannes with a convex curve under the cutting edge and no heel. That's one of my "go to" tools. I keep a slightly more trad. grind on my HT 3/8 spindle gouge -- short, 55-deg. bevel. I also have a HT 3/8U bowl gouge, but I find that I'm using it less and less in preference for the former two. It's pretty thin walled and doesn't go very far off the tool rest. ...Gary
