Staved Mahogany Plant Pot
gwilki
I glued up 24 staves, turned the outside round and routed out the top 2" of the inside. The outside dimensions are just under 20" in diameter, and about 16" tall. The platter under it is just over 24" in diameter. Finish is one coat of MinWax Sedona Red and one coat of Red Mahogany, followed by two coats of post-cat lacquer.
Re: Staved Mahogany Plant Pot
that's a beauty, Grant...
GaryG in MD
I love the color, and there's some nice stuff going on in the grain patterns.
It appears that you've lined it with black plastic to keep it dry. Very nice. ...Gary
And now you're actually going to...
JamieDonaldson
..fill it with dirt!!! :O :\ :(
Re: that's a beauty, Grant...
gwilki
Thanks, Gary. The wall is lined with heavy black plastic, with black silicone sealing it at the top. The dirt will come just above it. The bottom and the bottom 1" of the way is fiberglass mat and resin. With any kind of luck, it will last a while.
Beautiful
Roger Chandler
Very nice! Love the color of that wood..........mahogany is one of my favorites.
Grant Wilkinson
Jamie: Yup. By day's end, it will be full of dirt and plant. It's too small to be a hot tub, so I figured I would go with plant pot.
Tks, Roger. It does stain and finish well. I was lucky. A friend had a lot of off cuts left over from a big job. So, the price - nothing - was very right.
Don Leydens
Don Leydens
very nice piece, Grant. That's a classy plant pot. Killer finish too.
