I'm starting a new piece that is turned on 5 centers. I used the new bore sight in my taiilstock to align the piece on each center. I turned a #2 morse taper out of Walnut and bored a hole through the center with a drill that just barely fits the boresight. Then I coned the outer side of the hole to accept the tapered portion of the bore sight.
I put the wood on a scrap piece of pine and then used the bore sight to properly position the wood. It worked fantastic and I got exactly what was on my drawing. Now the fun part of carving away all the waste.
On this photo you can see some of the center marks drawn on the blank.
John, can you explain why you chose this solution instead of just pushing your tail stock point up against the blank and marking off the center? Am I missing something here?
It just gave me more room to work and it's a new toy so I wanted to use it. I also didn't want to take a chance at putting dent in the wood with the tailstock because some of the areas where the center is marked will be the final surface. Other areas will be carved away so it won't matter there.
John, now you need to get a high-power laser to burn patterns in the wood, could open up whole new decorating realms. Using the laser for alignment makes sense now after your last message
I use an old dead cup center as a drive center for teaching spindle turning, and with the point taken out, it has a nice little recess for a bit of pencil lead, a crayon, etc... I don't have one of those hollow tail centers used for boring out a lamp, but those could also hold a pencil or crayon.
I completely understand the urge to use cool new tools, and the great fun and creativity that can result -- just thought some folks might like a real inexpensive way to do this, maybe with stuff they already have on hand.
...NASA spending much time and about a million bucks to develop a pressurized ball point pen that astronauts could carry to use in the vacuum of space, and the Russians used a pencil!
I also know about that story Jamie - related to me by an aerospace engineer.
NASA's concern, I believe, was that use of pencils and the graphite therein, has the potential of generating airborne particles that are partially conductive, and had the chance of introducing problems with the complex electronics of the vehicle's equipment. Hence the generation of non-gravity writing implements that don't use possibly conductive particles.
This specific example from NASA pales in comparison to the multitude of expensive over-runs, "essential" support systems, and dead-end projects generated by military contractors.
I recently heard a quote that the Federal funding amount spent for NASA, spanning the entire 50 years of the manned space program, is less than one year of the annual budget spent on the military. Even if this is off by 20 or 30 percent, it still is sad to know that such a valuable contributor to useful "space age" technology has been so crippled in recent funding decisions.
We don't even have a vehicle to take OUR astronauts to and from the "International" space station - having to trust our continuation in this program by relying on Russian space vehicles just does not sit well with me at all! I did take courses in World History, the USSR, etc., and it doesn't seem right!!
