Problem with drilling using my Jet 1642
Starry Chan
I setup the lathe to drill a 1.5" recess in a round disc using a Forstner bit. As soon as I cranked the quill to start drilling, the disc grabbed the bit and pushed the tail stock backward. I tried different bits and I encountered the same problem. I tested the bits on the drill press and they are sharp. The tail stock was clamped as tight as I could. If I used the banjo to block the tail stock from moving, the headstock would move.
This is not the first time I used the lathe for drilling. I never have never encountered this problem. What did I do wrong?
Starry
