pen finish follow up...
GaryG in MD
OK, I've said I don't want to use CA inside because of the noxious vapor.
But let's say I did.
How do I keep from gluing the tubes to the mandrel?? ...Gary
Re: pen finish follow up...
Scott Greaves
Try some wax, like furniture wax or Rennisance wax on the mandrel and bushings.
Scott.
Brian McInturff
Like Scott said. I use a little Johnsons Paste Wax on the bushings.
Brandon
I've found that if you use a good full-face respirator, the fumes will not get to you. CA glue seems to be the best thing that works for pens, but that doesn't mean there isn't something better out there.
Are you milling your pen tubes before mounting on the lathe? This will handle the gluing issue most of the time, but if it's still happening, a wax compound will be helpful, but be sure to clear out the wax before assembly, as it tends to dry out, and make the transmission difficult to turn.
Also make sure you're giving your glue ample time to cure before mounting, it'll only heat up and dry out on the mandrel if it's not already fully cured. I ususally give it 24 hours between gluing tubes in the blanks and turning them.
Hope this helps
Dick Coers
Medium CA is better to use than thin, it won't wick between the blank and bushing as easily. Should you glue the bushings on, I use a utility knife at the seam with the lathe turned by hand. That scores the seam and won't let the finish chip into the blank.
Barry L Elder
TBC! (Turn between centers!) Now isn't that easy?! ;)
Brandon,
GaryG in MD
Thanks for your comments. My mistake for not being clearer. This relates to an earlier post. I'm talking about using CA as a surface finish, not for gluing in the tubes. I use 5-min. epoxy for that. ...Gary
Dick,
GaryG in MD
Good tips. Thanks.
I try to be very careful with CA, but Murphy rules -- I always manage to get it on something not intended. That's why I have an ironclad rule to always wear nitrile gloves when I work with it! ...Gary
Barry,
GaryG in MD
Yeah, that will work for a single-tube pen, but would be inefficient for two.
But, you're right, in that if I were to glue the tube to the mandrel, it would be a lot less efficient still! ...Gary
Scott,
GaryG in MD
OK, I will. I figured CA would eat right through wax, but that may be just the ticket. ...Gary
Brian,
GaryG in MD
OK, that's easy enough. Thanks. ...Gary
