do all tailstocks have a keeperplate? the one on my nova apparently ground into the shaft of the handle and ground the grove into a slope. it also made the keeper plate almost impossible to remove cause it chewed itself up and shredded the curved edge of the keeper and the shards wouldn't let it slip out of the slot it stays in.
i'll try to take photos of this tomorrow. I just read the above and confused myself.
If anyone followed that statement, have you ever had this problem and how does one keep it from happening? Probably gonna have to replace both the keeper plate and the tailstock handle. What really annoys me is that not too long ago i bought a turned walnut wheel for the tailstock that is much bigger and better than the nova, but it took me about 2 + hours to cut the handle off the nova handle, drill the new holes for the screws, and make it all happy again..I really don't want to have to do that again.
Re: nova tailstock question or tailstocks in general
Darrin I am also confused. It's been a while since I had my Nova 3000 and Nova Comet. I have turned on a Nova 16/24 and DVR but just can't remember much about the tailstock. Are you talking about the plate that locks the tailstock to the bed or some other part.
I seem to remember that the tailstock locking lever will hit the tailstock casting and not lock properly unless the nut on the bottom is adjusted properly but can't figure out what your trying to describe.
Bob Hackett
Are you talking about the thrust plate that secures the quill of the tailstock?
When I say quill I mean the part that advances out of the tailstock body when you turn the hand wheel. The part that holds a revolving center, drill chuck, etc by way of a tapered arbor.
Mike Mills
The keeperplate is a normal wear item and is about $3 from the service center. Mine is slightly worn and the next time I order something else I will order a new one. Did you keep/have the set screw tight from the crank side? If not the force can push it out of alignment. Did you oil it periodically (a drop or two) as suggested in the manual?
As to your question...I don't know if all tailstocks have them or not.
Terry Scott
Here is an answer I had back from a new Zealand Teknatool agent
Yes. This does not happen if users follow instructions about lubrication. This is less likely on the Stubby as the keeper plate is housed internally and packed with grease. The new DVR has similarly improved the system. Your old Tanner is one of the worst as it is almost impossible to lubricate the keeper plate - that is usually ok when the tailstock is not used for drilling.
At our club were we have 16 Teknatool lathes we have undertaken to lubricate once a mouth at our working bees
Mike Mills
Just as a possible hint, I use one of these. About $4-5. I filed the tip to accept a screw on hypodermic needle from the drug store. I use WD40 but any thin oil will do; I think it took a #10(?) needle for the oil to go through easily. Makes a lot of lube jobs (cables on tillers or mower, hinges) much easier than WD in aerosol that blows everywhere and you can also reach into tight areas like the keeper plate.
