Tool handles
Tool handles
Dick Hines
Tool handles
dick hines
Here is a picture of the tool handles I made over the weekend. A friend drilled them but he did not have large enough size bits so I had to buy two drill bits.
The one on the left is drilled to fit a 1/2" tool. The middle is drilled for qa 5/8" tool and will be used with the Kelton coreing standard set. The handle on the right is drilled to fit 5/8" tools.
I have ordered the handle wrap from Woodturners catalog to wrap them.
Re: Tool handles
Mike Stafford
Re: Tool handles
Mike Stafford
Dick, those are not made out of wood. I am not sure if you realize it but they are made from aluminium.....English pronunciation. Aluminum here in the U.S.
Re: Tool handles
Dick Hines
Re: Tool handles
dick hines
Close enough.
Re: Tool handles
Re: Tool handles
Lan Brady
Good Job Dick.
I hope they work well for you!
Lan
Re: Tool handles
Dick Hines
Re: Tool handles
dick hines
They feel good. I will let you know how they are when I get the wrap on.
Re: Tool handles
Re: Tool handles
Ron Bauer
Dick, Those do look nice. I aso make my own handles, albeit a little differently. Two comments, I bore both ends, usually with differant holes (i.e. 3/8 and 1/2 or 5/8) which essentially doubles your handle supply. Also the clear braided PVC tubing available from some of the industrial supply houses (like McMaster Carr or Grainger) make a great cover if the handle O.D. and the tubing I.D are compatible for a tight slip fit. Happy turning. Ron.
Re: Tool handles
Steven Antonucci
Tennis racket grip?
steven antonucci
Easy, comfortable, long lasting...
S
Re: Tool handles
Dick Hines
Re: Tool handles
dick hines
I looked at some tubeing for the handles but made them to big. The rods are 1 1/4" and with the tubeing they were going to be in the 2" range.
Re: Tool handles
Aage Rendalen
What do the aluminum bars cost?
Aage Rendalen
Dick, where did you buy the aluminum (tubes?) and what's the price pr foot?
Re: Tool handles
Dick Hines
Re: What do the aluminum bars cost?
dick hines
aage, I got the bars from www.speedymetal.com. The have rods and tubs. I got the rods because I could drill the to fit the tools. They have different knid os aluminum. I got the 6061 rods. I bought 36 inches and the postage was almost as much as the bars.
Speedy will cut the material amt length you want. The shipping may be cheaper if you get shorter pieces. Not sure about that though.
