Hickory Burl Platter
Dale Bright
This tray is from a piece of Hickory Burl a friend gave me, last spring. It had a lot of inclusions and a lot of rot. I intended to rough turn it and return it to the lathe after drying. When I took it out of the chuck and started cleaning the dust and some rot out, the tenon area simply fell apart. I decided to put into a large paper bag for drying for a few months.
This piece moved and warped a lot, as wet Hickory does, but I manged to jam chuck it for a little bottom clean up and then a lot of sanding, off the lathe.
The finish is just Walnut Oil.
I will post a reply with addition photos.
Size: 13" X 10" X 3"
Comments and critique are most welcome, thanks for looking.
