So I'm going through some of the tools I have but don't use and I find a Soren Berger hollowing tool that I had picked up cheap several years ago. So now to the questions.
1. What's the easiest way to sharpen and do you sharpen the end? Better to just buy the sharpening jig?
2. Is the tool strictly for going center out on the bottom of boxes?
I use the Berger tool a lot. I didn't "get it" when I first got it and it spent a lot of time in a drawer, but with a bit of playing around, I've found it to be quite versatile. I seldom take it to the grinder and just hone the edge lightly with a diamond card all the way around the rounded end. The cut is from center toward rim, and will cut from the bottom up, pulling, or from the top down, pushing. With green wood and hollow forms, I present the full cutter and pull wide streams of ribbon shavings out. It "hogs" out material faster than any other cutter in my arsenal. Present the cutter so that a smaller, (forward part) edge makes contact and you can make smaller cuts. Turn the cutter down (by rotating the handle) and make real light cuts and pull "angel hair" shavings. Especial good for straight sides of boxes and open vase forms. Mounted in a heavy bar, I get excellent control even at the bottoms of deep (12")forms.
Use it a good bit. Mine sat in the drawer a long time also. There is somewhat of a learning curve before you feel like it does any good. Agree with comments above. Think of it kind of like a gouge turned side ways. Rub the bevel and turn it up slightly to start cutting as you would a gouge.
Brain Not because I sell the tool and are the Nz Agent
But I think these are one of the best end grain box tool on the market.I only sell what I use and can put through the Terry Scott "if I cannot break it no one can test" (I admit I find the Hunter tool on a par)
I use mine or I should say more than one
Every time I turn a box
Just use a diamond hone bring the hone up to the bevel of the tool and a couple of swipes and shes good to go
Only use the sharpener if you need to reshape the tip due to a mishap with hitting something or dropping on the floor
My tips are 4 or 5 years old and with the diamond hone will last a while yet '
Using the jig is a bit of a knack and more lucky you will alter the tip so much its shot (from experience )
2. Is the tool strictly for going center out on the bottom of boxes? I say yes pre-drill to the depth you want to finish at draw across center out you are rubbing the bevel not scraping across the end grain .
When you come up the side of the wall turn the tool to the side bevel and draw out.I can cut the end grain on the bottom of a box so smooth I sand wet 1200 and then its finished
3 what position do you can't it to?
Under cutting I change to my Hunter bent tool after watching Mike Stafford On the Norway cruise the light bulb came on that I hadn't been rubbing the bevel enough when under cutting
4. How do you use it correctly? lol
Rub the bevel .The cutting area is right on the curve of the tip
Ive seen the tip placed in a big boring bar but there was no control at keeping on the bevel so it became a scraper
If you email me I can send the instruction sheet
Only to happy to walk you through the tools correct use
Or go to my web site and you can copy and paste from there.
Terry sent me a Berger tool more than a couple of years ago and I had difficulty finding its sweet spot. But as luck would have it Soren Berger was in the vendor area of a symposium I attended and I was able to get a hands on demonstration with the man himself.
Once Soren showed me how to use the tool I found it very useful for cleaning up straight sided boxes with flat interior bottoms. I still rough hollow the inside with a gouge as I have never gotten used to pre-drilling the center. After rough hollowing I use the same procedure Terry describes to clean up the interior.
I can do almost the same thing with my #3 or #5 Hunter straight tools but they will leave a radiused corner where the bottom meets the side. The Berger tool will leave a pretty sharp corner.
I sharpen the Berger with a diamond hone. Terry sent me a sheet from Soren explaining how to to that and I have yet to put the tip on the grinder. You can cut a lot of wood just by honing with a diamond.
I actually have the tool in both sizes and I use the small one for small straight sided/flat bottomed boxes and I use the larger one for, as you might guess, larger and deeper straight sided/flat bottomed boxes.
Seems like a tool I need to learn to use. thanks for all the detailed advice.
I remember playing with it when I recieved it but it seemed dull and I didn't have a clue on how to sharpen it.
There are 2 sizes? How do I determine which size I have and does someone carry both sizes. Packard only list one size and Soren doesn't list anything but the threader on his site now.
With Mikes article in Woodturning Design and my wife just recently asking about making some trinket/jewelry boxes then timing on this seems appropriate for me!
