Lighthouse bottle
This one should probably be tossed. This is green soft maple from the tree on campus. It tried to crack as I was hollowing it. 3 or 4 small splits opened up. I can't believe it did this because I turned the outside in a matter of minutes and then started hollowing. I sprayed it with water and they closed up. At least for now.
then when I stared to hollow it broke at the neck. Not completely off it just flexed and cracked on 2 sides. I didn't get a catch or anything and wasn't even being aggressive. I've hollowed this shape before on other woods and not had a problem. OK now I was upset and figured it was trash but I glued the cracks and decided I would just finish hollowing just for practice. It would be good practice for tall thin pieces since this wood obviously want to flex and chatter. so I hollowed it out down to the thin part of the neck and then drilled the rest out.
I couldn't turn it around and hollow the neck like I usually do because the wood at the base was just too weak. consequently the inside of the upper neck is slightly offcenter . I glued the upper finial into it. Now of course everyone wants to pull it out. I turned the lower ring and glued it over the crack.
I let it dry out overnight and then final sanded it and sprayed on a coat of lacquer. When I came back one of the cracks had opened up again, really big. I was not happy, mostly because I was trying to save a piece that should have been tossed. I came back about 2 hours later and the crack had closed up. I sprayed it some more and let it dry for another day. Then I cleaned out the hole and turned a plug out of the same Katalox wood and glued it in. There are two small cracks in it but only a turner would ever see them, they re really small and tight.
Can't decide if I like it or not. Will take it to the club meeting tonight and see what comments it gets. It's about 8" total made out of Sugar maple and Katalox.
