Jim On my old Taiwanesse Delta clone I wanted a riser block. I decided to buy one of the cheap Grizzly risers and then modified that to fit. The pins that locate it were not in the same locations. I did have to build some of the other things like the guide extension arm and the blade cover. All in all I think your probably better off just buying one of the official kits.
I had a Craftsman bandsaw with a 1/2 hp motor that was a little bit more than a little bit underpowered. I had a 1 HP motor from my Nova just sitting around after I bought the 1.5hp upgrade, so I thought... hmmm.
As John said, it's not just one thing. The new motor meant having to make a new motor mount (MDF in my case). In the end, I used it for inaccurate sawing until I bought my Rikon. It cost me a little bit more, but I got tired of hacking bits together to make something that wasn't that good only a little bit better.
But there was not need to get a bigger motor when I added my factory riser block.
I see the following issues:
1. There is a large bolt that holds the top of the bandsaw to the bottom. You will either need to get a longer bolt or extend the stock one.
2. In the stock frames and riser blocks, there are alignment pins that keep everything close to being in the same plane. You maybe able to duplicate this, but alignment will be difficult without it.
I tried to mess with making my own riser. Was not worth it. Ended up buying the kit and it works like a charm. I have a 2 hp motor on mine and it does all I need it to do,
Don't have a Delta, but thought about a home mede riser for my cheapie. Decided to spend and get the real thong. Installed in under an hour and works great.
I have the Jet 14" and purchased the riser block. I thought it was expensive but it came with a Longer guard, a longer bar for the height adjustment, and 1 new longer length blade there might have been a couple more items included but memory doesn't recollect. After I put it all together I thought it was well worth the price. I am sure Delta's riser package would be similar.
...really creates significant additional stress to the support frame, and I would not waste my time to patch together some Rube Goldberg modification. I used the Delta riser kit on my old Delta 14" for many years, but when I decided I needed more power the upgrade to a larger 18" saw was the best solution.
If you have good bearings on both wheels, and an overall well-aligned and carefully adjusted bandsaw, you may not need any more horsepower even with a riser block - try the saw first after you have added the riser block, etc. before you make that decision.
I would advise against trying to make your own riser block unless you have access to some serious metalworking tooling. As others have said, the riser 'kit' that is purchased is more than just the block itself - it contains new blade guards, alignment pins, a longer upper blade guide rod, new bolt, etc.
About 1.5 years ago I reconditioned an "older" Jet bandsaw (rescued from a farm barn) and added a new riser block kit to the tool when I reconditioned and repainted the saw; I had some 'issues' with making the new block fit an old saw - alignment pins were exactly opposite where they needed to be, etc.. I wrote this up in one of the customer reviews on Amazon.com, and if you're interested, you can find it through the link below (scroll down to 'Customer Reviews'). Have a read at what I did to adapt the riser block kit to the old saw I was restoring. At present, the refurbished 14" Jet "Metal-Wood" saw (3 speeds) works just fine; it is my second band saw or "blank prep saw" that is kept in the garage with the sole purpose of making rounds out of rough-cut log sections.
