A55 Smoothing Plane
This is a different way of turning beads *LINK*
I haven't seen it done this way before. Looks like a good opportunity for a catch but he seems to have it down. I'll have to give it a try.
http://www.youtube.com/watch?v=nk_rGxOZhZM&feature=g-vrec&context=G274f353RVAAAAAAAACw
Re: This is a different way of turning beads *LINK*
Bill White
Scared me, and I'm fearless (not).
Bill
Richard Jones
I'm with you, Bill. Not a chance in this world.
Jennifer Indy.USA
I would like to have seen a close up profile of those beads. I have a feeling they weren't very round on top. More like peaks. And I'm pretty certain there couldn't have been any coves by the way he was using that skew. I'm no bead expert but I'm thinking just by my own experience cutting beads and coves with both a skew and a spindle gouge that I can't imagine those in this video were very plump and rounded like a nice bead should be.
Jen
Phil Powell
Last month I did a demonstration at our club and cut some beads using my triangle tool. I've been doing it for a while and I like the results.
Carole Valentine
My thoughts exactly Jen! The way he is doing it I don't see how he could have any curvature on the side of the bead. I was practicing beads with a skew last night on a little piece of Boxwood. That wood is SOOOO wonderful! Slicker than a baby's butt when turned with a skew.
Dale Miner
It looks like he is using the skew as a positive rake scraper. I'm thinking in a harder wood, muscle alone might not be enough to prevent a run or dig in. I wonder if the surface is on the rough side.
Carol, practicing on boxwood? The horrors. I'm saving mine for that special project. I hope that special project comes along soon.
Carole Valentine
LOL! It was just a little cut-off Dale. Not good for anything else, except maybe buttons, and by the time I thought of that it was too late. I could have made a set of buttons for the lady that gave me the wood. She loved that big boxwood and was upset when it had to be taken out..
It was not my intention to put his technique down. At least not until I try it. I sort of looks like to me that he is more or less scraping using the skew as a negative rake scraper bit with it raised like that it's kind of a shear scrape. If done properly they could even be rounded. It may be this weekend before I have time to give it try. Who knows, might be a new technique.
The very deep narrow coves that I cut with the toe of the skew would scare most people also but it works.
Brian McInturff
The D-Way teardrop tool kind of works like this but the guy in the video didn't seem to raise and roll the skew. It appeared with his method it would've created a more triangle pattern that you would need to sand to make look like a bead. Of course watching his video you don't get a good view of what the tip is doing. Slight movements can make a big difference.
If you watch the D-Way video of the teardrop you'll see what I mean. I got the beading tools and teardrop a few weeks ago and haven't had a chance to do much with them other than try them out to see if I could cut beads and how easily I could with them.
My problem with cutting beads with the skew is I can't keep a uniform width and height of consecutive beads. So I need to cheat with something that makes it easier!
Brian the sides and top are easy, it's the shape that's difficult. Cut your V's which will be the bottom of the sides, the leave the top alone. When I first learned to turn beads the instructor (I have no idea who it was but might have been Nick Cook) told us to draw a line in the center of the bead. Then always start to the left or right of this line. That leaves the top correct. So you have the top and side it's that pesky rolling motion that's hard to do exactly the same every time. :)
Brian McInturff
John, I still draw the line. My problem is always the left side of the bead. I'm left handed. Something in the rolling action always screws me up. I really just need to practice. It's on my list of things to get better at this year turning. Maybe if I'd just dedicate one hour a week to practicing it I'd get it down. Yep. Think I'll do it on Wednesday nights, 1 hour. It starts tomorrow.
Brad Vietje
Brad Vietje
That's pretty interesting, John.
I saw a professional chair maker rough out his beads that way, all very quickly, then he flipped the skew over and rounded them off with a traditional finishing cut with the heel. His skew had a relatively short bevel, and a relatively low skew angle, too. I kept thinking I was about to witness a huge catch, but 'twas not to be. He'd made thousands of legs this way, and probably made 30 while we were demonstrating together under the same woodworking tent.
I've never tried it, but it looks pretty cool. It's probably like back hollowing -- looks pretty chancy till you understand the forces at play, then seems second nature.
Safe spinning,
Brad Vietje
Newbury, VT
Brian you don't even need that long. Put a scrap on and turn about 5 beads and then toss it. Don't take a lot of time and don't worry about the catches just concentrate on tool control.
That's how I learned to hand cut dovetails. I would go downstairs and cut just one each night. No chisels just saw as accurately as I could. That was my first task when entering the shop however many days a week that was. In about 2 weeks I was cutting them close enough that it took very little chisel work to clean them up.
Brian McInturff
Thanks John, I'll do that then. I always considered myself sort of ambidextrius but not rolling a bead it seems.
Keith Tompkins
Keith Tompkins
Hey John, I think to get a rounded bead, he would have to lose his "anchor" point on the toolrest and roll the tool...I'll try it as well. I do beads with the long point, but not the way he does it.
NO WAY Brad, will I ever consider....
JamieDonaldson
..Raffin's back hollowing technique to be easy enough to be "second nature!" :O
Doug Turner
John,
I have a home made 1/4" diameter pyramid tool from Hardened HSS m2 steel 8" long (use-enco.com for less than $3)that I use turn beads the same way. The three sided tip is much less prone to catching & can be used to cut like a skew or scrape. I also use this exclusively for making burn mark grooves prior to applying a piece of wire for for friction burning. It doesnt skate making grooves like a skew sometimes will. There are some videos demonstrating on the web, but I don't have a link.
Doug
