Great Bandsaw tip in this video
Steven Antonucci
steven antonucci
If you watch the video, watch how he only cuts one of the two pieces flat. It will be obvious why when he gets to the bandsaw part.
Steve
Re: Great Bandsaw tip in this video
Mike Stafford
Mike Stafford
I know the video action is speeded up but Glenn Lucas turns a bowl that quickly.
Never thought about using the cut offs to cradle the round side of the blank. I made angled supports from rough stock that I had..... Doh!
Jim Breeden
Fascinating! :O Question: How did he get that polished finish with only the sander?
Dick Hines
dick hines
Why even cut the blank round. Just put it between centers and use a bowl gouge to do the work. I can't remember the last log I cut into a round blank.
Carole Valentine
Why doesn't he cut it round with the larger flat side down so everything is supported? What am I missing here?
And what kind of lathe its that? The motor is so close to the work.
Jennifer Indy.USA
I'm thinking the same thing? Use the larger flat side down and use a circle template. And if you must use just the small flat side cut with the chain saw, I'm assuming so you can draw a full circle on the cut side, why not cut both sides with a flat and then cut the log in half and not mess with the little craddle pieces? He also needs to cut a V in his chain sawing stump. His little blocks aren't helping much.
Just my observations.....
clay foster
Why not cut a flat on both halves instead of messing around with those cradle cutoffs? If he cut a V notch in the top of the stump, the log would be a lot more stable than those loose boards he's trying to hold the log between.
Jim Breeden
Maybe Steve is trying to tell us something? 8)
I agree with Jennifer. Although the wedges seem to work all it takes is once for it to slip and you could hurt your self. I prefer to put the big side down and use my templates.
Bill White
Dang! I thought that I was the only feller who turned that fast. I'm busted.
Bill :D
Steven Antonucci
I seriously think it's a good tip.
steven antonucci
I didn't post this as a "wow, look at what he's doing" type of video.
I thought it was a good tip.
If you've ever cut a rounded blank without support, you quickly learn how dangerous it is (and get good at changing your blade).
Why might I leave the rounded side? I may want the sapwood to be an accent on a cherry/walnut turning. I may want a natural edge. Cutting away the corners may make it fit over the lathe and seeing the bottom may help me visualize the thing I am making better.
Nope, I just thought it was a good time. No subtext...
Steve
Brad Vietje
Even BETTER Band-Saw Tip
Brad Vietje
Cut with the big side DOWN!!!!!!
It drives me freakin' crazy seeing people push an unsupported chunk of wood into a running bandsaw. That's just too risky to be considered smart -- even with the small flat that he prepared with the chain saw.
Supporting the upper edge with a wedge of wood is better, but those first few cuts could spell disaster - why do it?
I made up a series of wooden discs from 6" to 12" in diameter, which can be tacked to the smaller face (or round bark surface) of a billet, and all one needs to do is select the best size template, tap it in place with a nail, and cut around it. For bigger than 12" I cut the corners off with the chain saw, and round it up on the lathe.
I've seen some pretty violent bandsaw "accidents", and I can assure you, most accidents happen because someone failed to prevent them. Doing something overtly stupid just raises the chances of a Darwin Award.
Safe spinning,
Brad Vietje
Newbury, VT
Mike Stafford
Mike Stafford
If it is important to you with regard to how the grain is centered in the bowl it makes sense to round up your blank with that surface up so that you can see what you are doing. I use a circle template centered on the grain pattern I hope to have inside the bowl with the flat side up. Then I use my wedges to keep the blank from tipping as I saw off the waste.
I don't believe the gentleman in the video had any concerns about the grain alignment.
If the grain alignment is unimportant then by all means put the flat side down and use a circle template. Or even better just mount between centers or on a screw and turn the darn corners off with your bowl gouge. Wait, someone already said that.
Brad Vietje
Slight Variation...
Brad Vietje
I usually round the blank on the lathe with a bowl gouge, mostly because I'm not trying to pay the bills through turning, so a little lost time isn't costing me income. When I use the bandsaw, I always cut with the big face down, and cut out the largest diameter that I can.
In either case, I then turn the bowl between centers so I can balance the figure, sapwood, etc... before committing to a tenon or a screw chuck.
So I'd say even if you are taking care to balance the appearance of the bowl, its still possible to cut the circles wide side down (bark up) for greater stability and safety, and rough turn between centers.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Even BETTER Band-Saw Tip
Right you are. And accidents on the bandsaw happen with lightening speed. I've had one close call. Well it probably wasn't that close because I always keep my hands out of the way as much as possible. However the catch was really violent and if I had my hands close I could have lost something before I could blink my eye.
I think what happened was the wood was not totally flat on the bottom and as I rotated it around it suddenly rocked to the unsupported side and pulled the wood over jamming the blade. I keep my hands as far to the left and right as possible and never inline with the blade. That save me I'm sure but did scare me.
I now check the wood more closely and will hot glue a wedge under it if necessary.
Mike Stafford
Respect the band saw!
Mike Stafford
As my dear departed friend Ed Moore so frequently advised after he had his band saw accident, "RESPECT THE BAND SAW!"
I hear that echo as well Mike.
Me 2, just before I push that green button
Keith Tompkins
Re: Even BETTER Band-Saw Tip *LINK*
Keith Tompkins
Here's a link to a bandsaw safety article I wrote for American Woodturner Magazine. Think twice before emulating the bandsaw technique shown in the video. Unsupported cuts are the most frequent cause of horrific bandsaw accidents...totally preventable accidents, I might add.
http://www.keithptompkins.com/storage/bandsawsafety.pdf
