Tap and die
Tap and die
Dick Hines
Tap and die
dick hines
I am making some tool handles from aluminum rod. Need to know what size drill bit I need for a 1/4'x20 allan screw.
I have looked at the charts but it looks all Greek to me.
Re: Tap and die
Re: Tap and die
Carol
Re: Tap and die
Re: Tap and die
Dick Coers
#7 is the recommended size which is .201"
Close in fractional size is 13/64" which is .203"
Re: Tap and die
Re: Tap and die
Roger
Dick,
I sometimes drill a "practice" hole or two in some scrap to test sizes before drilling the hole in the piece I'm working on.
Re: Tap and die
Lyle Jamieson
Re: Tap and die
Lyle Jamieson
Dick and Carol are correct. It is strange that the threads have a different scale for the drills needed. They go by numbers not fractions, in inches. You can find number drills in the old fashond hardwares, like Ace hardware. I would guess that it would be rare to find them in a big box store.
Re: Tap and die
Re: Tap and die
Carol
Actually, places like Ace sell the bit and the tap packaged together. What's not to like? :)
A tip. I use a single flute countersink and drill a slight chamfer on the hole. Really helps get the tap started correctly and does away with the 'mushroom.'
Re: Tap and die
Mike Hunter
Re: Tap and die
Mike Hunter
Dick ... why don't you go with 5/16-18. The allen wrench is the same as most chuck jaw screws and this T-handle wrench is generally handy.
Re: Tap and die
Re: Tap and die
Roy
That will take a F drill bit.
Re: Tap and die
Re: Tap and die
Bruce Smith
Most taps are marked with the required drill size right on the side below the pitch & size. Like Lyle
says they are usually number size but some have letter size.
Re: Tap and die
Re: Tap and die
jim 9 miles
Noticed over weekend that Lowe's had taps & drill bits packaged together.
Re: Tap and die
Dick Hines
Re: Tap and die
dick hines
Thank's for all the info. As far as the taps being marked with the drill size. the set I have is a CHEAP one I have had for years.
I am off to the tool store for a new set.
Re: Tap and die
Re: Tap and die
Coyne
Where else can one ask a question and get that much helpful information and friendly advice?
Re: Tap and die
Dick Hines
Re: Tap and die
dick hines
The only place I know of the kayak fishing page I go to. Ask a question and they come form everywhere just like Wooid Central.
We are lucky that Ellis has this sight.
Thank's Ellis.
Re: Tap and die
Re: Tap and die
Bill White
Aluminum? I haven't thought of that.
Bill
