Vacuum Chucking Procedure - Tip ?
Doc Green
I use only shop-made vacuum chucks, made from MDF, PVC couplers, and so forth, and I have quite an assortment of these chucks in various sizes and shapes. Here's the point:
Without turning the vacuum system on, vacuum chucks make good jam chucks.
To place a workpiece on a vacuum chuck (typically a bowl), standard practice is to use the tailstock to center the piece on the chuck. The tail center pushes the piece against the vacuum chuck, and if you apply just a moderate pressure against the piece, the tail center will hold the piece securely. This is jam chucking, pure and simple, even though you're using a vacuum chuck.
So typically, I do most of the turning (removing a tenon, or whatever) with the tailstock in place without even turning the vacuum pump On. Then, toward the end, I will start the vacuum pump, move the tailstock back, and finish the job using the vacuum.
The result is that I usually run the vacuum system for only a couple of minutes, five at the most, depending on how much sanding or detail work I do on the bottom of the piece.
Advantages: First, the point of the tail center gives an extra measure of support against sideways movement of the workpiece, which is the weaker direction for vacuum chucking. Second, a power failure will have no effect because I'm not even using the vacuum for most of the operation. And third, it reduces the wear and tear, if any, on the vacuum system.
So you say, why bother with the vacuum system at all if you are going to use it like a jam chuck? Why not just turn it down to a nubbin and then remove the nubbin off-the-lathe as is normally done?
The vacuum provides insurance against having the nubbin break away prematurely, which would release the workpiece. This is especially significant if a waste block has been glued onto the bottom of the piece with the tenon cut in the waste block. The risk, in this case, is that the glue joint may fail at the point of the nubbin, after you have turned most of the waste block away.
This is the method I use. You may prefer a different one, and that's OK. :)
~Doc
Re: Vacuum Chucking Procedure - Tip ?
Bruce Smith
Doc I think that is a fine idea and I shall try it out. I always worry about power failures when I
use my vacuum chuck, then again we haven't had one in years but one never knows and it
always nice to be prepared.
Bill Blasic
Bill Blasic
Doc,
Great idea, Thanks!
Bill
George Van Beynen
Doc, I use the vacuum chucks like you do. I really like the support of the tailstock, but also appreciate the vacuum pump (if the piece will hold vacuum) at the end when it is time to remove the nub and decorate the bottom of the piece to my satisfaction.
Bill Howatt
Although conditions vary because not all bowls exhibit the same degree of vacuum leakage, you can do a simple test on your system to get an idea of what happens in a power failure. Arrange to simultaneously kill the power to both the lathe and the vacuum pump and see if the vacuum holds enough for the lathe to spin down. If you have a VFD lathe don't just turn it off since that may not be the same as a loss of power. You can mount a typical sized bowl you don't care much about for the test.
It takes very little vacuum to hold the bowl on the chuck if you aren't cutting, and you likely will quickly stop when the lights go off. I have an old 2 cylinder refrigeration pump for a vacuum source and it will easily allow my lathe to stop before the vacuum gets too low.
My lathe room has very little natural lighting so I have installed a battery-operated emergency light. I've never had a power failure while turning (yet).
Bill
Stuart Johnson
I know for fact if you have a brain misfire and hit the switch to the vacuum pump instead the lathe without the tailstock pressure your piece will hit every solid, sharp edge in the shop and then bounce at least two feet when it hits the floor.
Steve Kubien
Steve Kubien
Thanks for this tip Doc. It makes perfect sense and I will remember this when I venture into vacuum cchucking (soon, I hope).
Great Minds Think Alike!
Don Orr
I've been doing just as you describe since I started using a vac system a few years ago. I t works very well. I guess I figured everybody did it this way. If my poor old brain can figure it out I thought anyone else sure could! :D ;)
I'm honored . . .
Doc Green
to be in your company, Don. :)
Thanks to everyone for the comments. Very informative. ~Doc
Bill Howatt
I can hold a 12" bowl (no cutting) on my 5" drum chuck with 5-6" of vacuum at about 700 RPM and perhaps higher. Now the question is how fast does the lathe run down in RPM vs how fast does the vacuum drop to 5". Unfortunately this is governed by the leak-rate of the bowl as well as the system so there isn't a hard answer. Also the how well the shape of the bowl curves around the drum chuck to help counteract the centrifugal force is another variable.
I am not advocating the tailstock not be used but saying in some situations a power failure may not spell definite doom and doing a test with a tight bowl/system will give some indication of the best results you can expect.
Bill
Jack Brown
Stuart,
A switch on a vacuum pump is a bad thing. I plug into a wall outlet about 10 ft.away. With duct tape to hold it in. Then you have to think before unplugging.
