After reading the latest on-line flyer from Woodcraft, which is currently having a sale on Teknatool chucks and accessories, I would like to ask if anyone knows whether chuck jaws for the Nova, Supernova 2, or other Teknatool chucks would be compatible with Vicmarc VM-100 chucks? I have never worked with Teknatool chucks at all, but the jaws appear to be very similar to Vicmarc jaws. [I do know that the jaws sold for the Grizzly knock-off of the VM-100 will work with the authentic Vicmarc chuck body.] A search of the WC Archives did not yield a direct answer to this question....
Does anyone have experience with both brands who would know if you could use Nova/Supernova jaws on the Vicmarc VM-100?
(I assume they are incompatible and brand-specific, but if they COULD be used interchangeably, this would open up an entirely new set of possibilities!)
Thanks for any experience you may be able to share...
I read the "What chuck to buy" piece in Russ's Corner twice, prior to posting my question, and despite the fact that the text is a bit dated, it is still very useful information.
There is no specific discussion included in Russ' summary of whether Teknatool jaws will work on a Vicmarc (VM-100) chuck body. In fact, in the article he admits that he did not use Vicmarc chucks very much, and that they rust a lot (I don't agree with this -- I have 5 Vicmarc chucks, and none of them show signs of rusting, even after 10+ years of continuous use for some of them!).
Still looking for information about this inter-brand compatibility (or not).
I will probably go ahead and order the 75mm bowl set and give it a try, assuming they are compatible with the VM-100 (worst that can happen is that I return the jaws to Woodcraft).
I very much like the hold of the serrated jaws that Oneway includes on their Talon and Stronghold chucks (Vicmarc doesn't manufacture jaws that are similarly serrated), so the serrated jaws that Teknatool sells might be a great compromise.
I am 'standardized' with Vicmarc chucks here (4 VM-100's and 1 VM-120, plus the Grizzly knock-off of the VM-100 that I use in the carving stand), preferring the hex-key drive of the Vicmarcs to the geared handle used by Oneway (and others).
The 'Clones got by K-State in hoops yesterday, and hopefully they will make it to the final four - that would be a big boost to the B-ball program here. I actually LIKE the coach we have right now (Hoiberg) - my daughter used to babysit his kids! He's turned around the ISU program quite a bit to the positive side!
Thanks again - I'll post the results of trying the Teknatool jaws on the Vicmarc VM-100 one they are received....
Rob: Didn't mean to lead you astray. When I was looking for information about chucks that were interchangeable, the only info at the time, I could find was here at WC. Sure wish I had the information I now have. Wouild have saved me a lot of green stuff.
Rob I have a couple of Vic VM100 chucks and 3 of the compatiable Griz chucks. I had a SN2 chuck I bought from CSUSA last year. I could not get the jaws to fit the Vic. The screw hole spacing was different. I sold the SN2 chuck because I didn't want different brands of chucks.
You would think that if the Nova jaws fit the Vicmarc that the Vicmarc would fit the Nova. I wanted the Dick Sing jaws from Vicmarc but they do not fit the Novas, I had to buy adapters to fit the Vicmarc jaws to the Nova. So that leaves me to believe that the Nova jaws will not fit the Vicmarc. I am a firm believer that a properly made dovetail cut into a solid piece of wood is as good at holding the piece as anything else.
