How do we make a better beading tool
This is my mini beading tool that I made for the Genie bottles. I made it from a screwdriver but it needs improvement. I'm going to start a thread on beading tools to see if we can improve them.
On this one I simply filed a groove using a jewelers rat tail file. I think when I have time this weekend I'm going to try and file it so it has a much sharper angle from the bottom and possibly put a negative rake on the top to make it an even sharper angle. It might not hold an edge long but should cut like a skew on it's side.
I'm having trouble with tearout on the very crest of the beads. I've always had this problem with beading tools. I start with the tool below center and the push the handle down do raise the cutter through the work. That seems to cut the sides very clean but I can easily get chip out on the crest of the bead because at that point it's just scraping. I would love to come up with a way to make it a shear scrape or a cut.
One thing I thought of which I will try today is to use it as a bevel rubbing tool. If I grind the bottom so it has a bevel it might work. However I'm worried that the tips would be too weak and possible break off on harder woods. I could make them wider but then that leaves a wider space between the beads.
Anyone have any suggestions. I guess I probably should have put something in here for size comparison. This is less than 1/8" bead, maybe 3/32 or so.
Maybe we could do a mind meld.
