Chemical exposure and sensitivities, LONG
Dick Coers
I know I'm opening myself up to some critics here, but wanted to find out if others may be battling something like this. The age demographic for turners makes me interested in asking others. I have suffered on and off for over 5 years now with something that causes pretty bad fatigue. Thousands of dollars of testing, and all that ever shows up is a high reading for Epstein-Barr. Negative for lyme and a host of other tests. I'm on natural thyroid, and eat gluten free. I can still get in some pretty bad weeks, but then do okay for a while. Yesterday, I read something about chemical exposure, and the use of tung oil in particular. There is some research that shows exposure to tung oil can cause trouble. Quote; "This is because it’s been implicated in suppressing immune system functions, as well as reactivating chronic Epstein-Barr virus infections." So I'm rethinking the use of Waterlox and Minwax wipe on poly. I have a sample of Enduro from General Finsihes on the way. It's MSDS doesn't read too friendly, but I still need something that builds for the high gloss hollow forms I do. Anyone have chemical sensitivity experience they can share? Fatigue issues? I've been woodworking for 40+ years, and have sprayed lots of finishes. I had a business for 8 years, from '88 to '96 and I bought the finishes in 5 gallon buckets back then. Now I mainly do wipe on finishes at home, and roll on latex at my day job as a modelmaker. I do sometimes spray a small amount at work from an aerosol, but very seldom. Thanks for any help.
Re: Chemical exposure and sensitivities, LONG
Jon Behnke
I don' have any experience with exposure issues so I can't speak to that but would like to offer up another alternative finish. General Finishes is located here in Wisconsin, we had a rep come to our club meeting and talk about their new WoodTurners finish. This is a water based finish that I think is urethane based that builds up nicely and buffs out with a nice glossy finish. It takes several coats but it dries quickly so you can re-apply in a matter of minutes. It can be wiped on, brushed on or sprayed on. It is said to also be very durable as it was derived from one of their floor finishes. I used it on a pepper mill and a natural edge bowl that turned out very nice. I'll next do some experimenting using it on pens, it may be a good alternative to CA finishes.
Keith Tompkins
Re: lyme OT rant
Keith Tompkins
HI Dick, I can relate. I went six years with undiagnosed and untreated Lyme Disease. I can tell you from experience that the tests for Lyme are absolute bullshit. The only way they finally diagnosed me was a culture grown from a spinal tap. I thought I was going to die....my immune system was fighting itself; my beard fell out, along with big patches of my scalp, and my fingernails began to fall out as well. Not to mention nearly uncontrollable anger, memory loss, and heart problems, along with the more common symptoms. The only reason I got the spinal tap was because they thought I had developed menningitis. I understand there is a new genetic test for Lyme that's 100 percent accurate. Intravienous (sp) antibiotics was the answer for me. Don't give up...get more opinions...don't settle for feeble guesses.I don't know about chemical exposure, but I've had my share, and I'm now completely norbl. :P
Betty Scarpino
Betty Scarpino
I second what Keith said about Lyme disease. It does test false-negative.
Beyond that, you've not said if you use gloves when applying finishes or if you regularly breathe the fumes? If either of these are true, you could have fatigue (and other) problems from exposure. Exposure is cumulative.
I now take care of my Mom who is 87 years old. She has sensitive skin and has had problems with her skin itching for no apparent reason the past few years. She was doing fine and getting stronger (after breaking a hip and having a skin disorder). Then she insisted on getting a permanent. A day and a half later, her skin started to itch all over her body, she was incredibly fatigued, depressed, and for about two weeks her hair was falling out. Now it's three weeks later and she's doing much better. She's not going to like it, but I am not going to let her have a permanent again. Those chemicals are quite harsh and she's been having a permanent several times a year for decades.
I'd vaguely noticed the connection between her health and a permanent previously, but this time it was direct and obvious.
Good luck figuring out what is causing your fatigue and health problems. Maybe keeping a journal of how you feel daily as well as what chemicals you are working with might shed some light (or eliminate some possibilities).
Among your tests did you have a .....
JamieDonaldson
...sleep study done to determine if you are suffering from sleep apnea? Chronic fatigue is one of the insidious side effects, and it can be a very serious health problem.
Jim Evans
Jim Evans
I'm not sure what natural thyroid is? I'm on synthroid because my thyroid was removed because of cancer.
I know that if your TSH gets to high you will have severe fatigue, and it takes awhile to get your strength back.
Also what Jamie said about sleep apnea.
Caution more info, but may bore a lot of you
Dick Coers
Thanks for asking questions and the help. This is going to bore a lot of people, so avert your eyes if you are not interested. I started complaining about fatigue and my general MD had me take a sleep study. I was diagnosed with obstructive sleep apnea in 2006 and had a second sleep study in 2008. I wear a CPAP every night. When I was on Synthroid, I was put on disability. That was at the end of 2007. I had to take a nap everyday at work to get by. The company medical director even ran a couple of tests on me testing my adrenal glands. I started going to a holistic MD a few months before being put on disability. She switched me to Armour Thyroid. It is made from dried pig thyroid. You get T3 and T4 with it, plus some trace hormones. They stopped production for a while and became unavailable. Now I get Erfa thyroid from Canada. It is made the same way as Armour. I was on disability for 6 months. This week I started thinking about chemicals because I felt so bad this week, and also since I put finish on 8 bowls and vessels in the past couple weeks. I put Waterlox on a couple, Minwax wipe on a the others. I don't always wear gloves because I fold up a paper towel and use it a bit like a brush. Maybe just a little finish material on a couple finger tips. There is out gassing since I do this in our basement. Might just be enough though.
Don't ignore Med's
Steve Mushinski
Another chemical that is sometimes forgot about is Med's you might be taking. There are many of them so called safe medicalions that can slowly disable you and down right kill you.
For me it was "Lipitor" , stuff just about killed me. I was in such bad shape for a while I could not remember anyone's name outside people I seen everyday. My back hurt so bad, I was in tears most nights trying to get to sleep. Since all my blood work was always good the Doc said it cannot be the Lipitor. It was!
Here is an example of real world problems with statin drugs:
People have reported "trouble swallowing, trouble talking and enunciating words, feeling fatigued all the time, neck aches," "motor neuropathy which mimics ALS," "Blinding headaches, nausea, vertigo, disorientation, memory loss, extremely dry eyes, pain and stiffness in my neck and calf muscles, abominal pain," and "Muscle pain, weakness, spasms, buzzing in right leg. Can't hold arms or head up in vertical position for 2 minutes without extreme pain and weakness."
Some of these problems are very slow to develop so you do not notice something is wrong until the damage is done.
Since I stopped taking the drug most of the problems I was having are gone. I still have eye problems and some perment muscle damage. I still drop things for no reason what so ever. My memory has come back as good as it was before. It was the lost of my memory that scared me the most, which had me looking for answers.
Terry Scott
http://www.brendasampson.wellington.net.nz/di.html
The above makes interesting reading
We have put my hole family through Mat Tizzard
Barbara Gill
Betty, before you make you mother very unhappy (my mother is the same as so far as wanting her hair to look nice), check with the salon. I think they might have products for sensitive people.
Betty Scarpino
Betty Scarpino
Thank you Barbara, I figured that would be the case, but like Dick has revealed, there are other considerations that make Mom's situation difficult to "fix."
Steve Kubien
Re: Among your tests did you have a .....
Steve Kubien
I was diagnosed with sleep apnea over 10 years ago. I now use a CPAP and it has changed my life significantly. If someone tried to take my machine away, well, your 2nd Amendment would not save you. :)
I've been feeling sluggish, off and on for a few months. I'm going for a fresh sleep study on Monday because I think my CPAP prescription/pressure needs to be adjusted.
Steve Kubien
Re: Caution more info, but may bore a lot of you
Steve Kubien
Your last sleep study was in 2008? I'm not a doctor but I have sleep apnea and methinks you need to book a new study. Your prescription will have likely changed and it is a whole lot easier to adjust a CPAP than hit and miss with meds.
Jim Evans
Jim Evans
While you are at it have them check your blood oxygen level. Most people's blood oxygen level drops during sleep, in my case it dropped to about 88% which is low, so they added an oxygen concentrator to my CPAP and it made a difference.
