200+ woodworking book reviews
Pencil disassembly
Pencil disassembly
Pencil disassembly
Royce Meritt
I've not had a lot of success with mechanical pencil sets. The mechanisms seem a little unreliable. Might have to try to find a higher quality kit if I make more.
Anyway, I have some pencils that I'd like to switch over to pen kits. Anyone have any suggestions for disassembly of slimlne pencil kits? I have the punches that work for disassembling pens but they don't work for the slimline pencils. Since the slimline pencil kit doesn't come apart at the center like a slimline pen kit does, the punches aren't long enough.
Any ideas? Thanks.
Re: Pencil disassembly
Stuart Johnson
I use a piece of 1/8" brass rod (Ace Hardware or Lowe's) to disassemble pens. This can be cut to any length and might work.
John Kaner
Royce,
I had a problem with pencils not working well. Found it was the eraser cover (trim). It stuck because of some "flash"... Little filing and worked great.
It had worked well with the trim piece off...
To dissemble a pencil:
Remove nib and pencil mechanism.
Using hands, pull the two halves apart.
Use pliers to remove center connector in other half.
Use punch to remove clip.
Voila' Add pen kit and press into previous pencil barrels...
Hope this helps...
Re: Pencil disassembly *LINK*
Andy Lincoln,in Dearborn MI
Royce,
I too was frustrated by the lack of quality in any of the mechanical pencil kits I found.
I began researching using the Pentel mechanics in a wooden turned pencil.
I found a supplier on the web that makes a mandrel/bushing/drill bit set that takes alot of the frustration away.
I have always used the Pentel mechanical pencils while at work in the 0.9mm lead,which I have yet to see in a kit form.Now I have the ability to make my own "custom" pencils.
They are still touchy to get right,sometimes get turned too thin,sometimes they fracture on the lathe.My rate of success is getting much higher.
These are made from Redheart which was a new wood for me and the wood turned extremely well,smooth,easy to cut.
I realize this wasn't a direct answer to your question but felt the subject matter fit into the thread.
The usual disclaimer applies,no financial interest,no affiliation with the linked site,etc.just a customer.
Andy
Perfect Mandrel
