From chat - basket weave close up
Molly Winton
As we discussed in chat tonight, here's a close up on where I adjusted the branding as the diameter of the piece decreases. The pattern eventually catches up with itself and results in a bottom row lining up with the top row and having two horizontals or two verticals in line. When that happens I stop, and burn two touches perpendicular to the one above to avoid having three touches in the same orientation on top of each other. I start the next row where I've set the perpendicular burn. Hope this makes sense. It's difficult to describe in writing.
Re: From chat - basket weave close up
Thanks for chatting & posting the picture
Cynthia Gibson
Nooooo, I still don't understand!!! too complicated for this feeble mind! You certainly have this technique down pat,Molly! I really enjoyed the chat last night! Wish we lived closer..I'd love to have a girl's day in the workshop! Can't wait to see our piece!
Carole Valentine
If it makes you feel any better Cynthia, I don't either!
I understand the problem because I've had it when doing some carved decorations. I'm not sure I understand the solution exactly. As you go down the vessel the number of burns drops from say 24 per revolution to 23, then 22 etc. Eventually the vertical lines from one ring start to line up with the vertical lines from the lower ring. that's what's in the middle of her photo. This probably only happens on one side of that ring, the other side probably looks roughly normal but I'm guessing here. It sound like what she is doing at that point is starting the next ring under this area with a burn that is perpendicular to where they line up so you eye doesn't see 3 of the same burn pattern in a row.
When I do carved details usually there is a space between the details. what I can do is change the space slightly as I work around the vessel so it comes out with looking right even though the dot spacing is different. Molly doesn't have that option because her designs are right beside each other with no spaces.
by the way if you haven't tried this basket weave pattern it isn't as easy as it looks. It take patience and skill to get everything to line up as well as Molly does. I used to do the basket weave pattern in leather working and it's challenging getting everything to line up and my pieces were mostly flat, not curved like Molly's
Cynthia Gibson
Yea, John! I had a difficult time with the basket weave belt and cell phone case I tooled for Michael. You are right, it IS NOT as easy as it appears.I think I'll leave the basket weave alone and do flowers on leather as well as wood! : :D
Brian McInturff
Thanks Molly. That answered my question. With the pic, your explanation, and Johns I totally get it now. Not sure I will attempt it though. I think your basket weaves are the best I've seen. I absolutely love them.
John, an excellent description!
