REAL MILK PAINT
Tubing for sphere turning?
Tony - Memphis
Just wondering what sort of tubing might be good to sharpen up and cut spheres with? Haven't tried it yet, but it is a technique I've erad about and been meaning to try. I noticed a lot of tubing is welded and has a seam that might mess things up. I looked at EMT and regular tubing in the hobby rack at Lowes yesterday.
Thanks,
Tony
Re: Tubing for sphere turning?
I've read where people grind the teeth off of a hole saw. I tried it with some pipe I had and didn't think it came out that well.
R Henrickson
My brother did a couple for me, since he has access to a metal lathe. He tried taking the teeth off a hole saw. At best, the process frustrated him, and the result was useless. He also turned a taper onto the end of a piece of 2" inside diameter black iron gas pipe. That was reasonably successful, though 1 1/2" I.D. would probably be more useful (I was working on a sphere just over 3" in diameter).
Keith Tompkins
Keith Tompkins
Hi Tony, that's how I did this piece; I used a piece of steel tube, ground and honed on the outside, honed on the inside as well. Hope this helps.
what nose angle?
GaryG in MD
Keith, I've tried it with black pipe and not been very satisfied.
I suspect the nose angle has a lot to do with success/failure.
I've decided that a very "blunt" angle (like the kind you use to go across the bottom of a bowl) might work better than a "sharp" angle.
What are your thoughts?
(And why, given all your tools, did you use it on that beautiful wood?)
...Gary
Keith Tompkins
Re: what nose angle?
Keith Tompkins
Hi Gary, I should have clarified...I used the hollow pipe to turn the spheres I used as a finial...they are all 1/4" diameter. I sharpened the pipe with a long bevel, perhaps 40-45 degrees. Each sphere was then drilled, and supported with guitar string.
arch punch
Dave Staeheli
I've been using an "arch punch". Good steel and perfectly round, which hole saws are not. Initially you can use it without modification, but then I just rub the cutting edge against a diamond hone. Yes, it flattens the edge, but creates a new edge with the flattened edge and the inside bevel. Remember, it is the inside edge that does the cutting on a sphere. A bit pricy though, especially in the larger sizes.
tricky!
Fred Holder
Several year ago when I started making the Chinese Balls, I made a swinging jig out of plywood as shown in the photograph. I used this for several years and then began using ones made from metal. The swinging portion was made of three layers of 3/8 inch quality plywood, with the center piece 3/8 inch below the top of the other two. A piece on top had a screw hole to lock the tool in place.
The swinging jig makes the best spheres that one can make.
Mike Stafford
Mike Stafford
This is a jig that Arne Sortland built and posted which he uses to create spheres. He uses a Hunter carbide cutter on the business end.
Fred Holder
On both of my current jigs: One by Vermec in Australia and one from Fred Lindsay in the United States. I use Hunter Carbide cutters on both of them with great results. It is hard to beat the Hunter Carbide cutters for any purpose.
