Skew Sharpening with a Belt Sander *LINK*
Doc Green
Congratulations, John, on the 41,000 views of your video collection. That's impressive!
A different approach to sharpening a skew, and the method I prefer, is to use a belt sander. This method automatically gives flat bevels and can be used for either straight-edge or radiused skews. Plus, you can use a fine-grit belt to produce a really fine edge.
It does require building a fixture for holding the belt sander upside down and keeping the switch turned On if it doesn't lock. The details of this will be dictated by the shape of the sander.
Here's a link to the article (no video):
Doc's Website, Sharpening a Skew
Re: Skew Sharpening with a Belt Sander *LINK*
doc I had intended to show that method but couldn't find my old jig for holding my belt sander. One word of caution. Remove the cloth dust collector bag from the sander before you sharpen. You don't need to ask how I know to do this but my bag now has about 10 small burned holes in it. :)
Steven Antonucci
How I sharpen mine too...
steven antonucci
I use a bench vise to hold my belt sander. A slightly worn 400 grit belt produces a polished edge that you simply cannot get on a grinder (even my Tormek!)
I freehand them, and I do all 4 skews at one time. Honing in between with a green DMT stone and a charged leather strop.
Steve
Brad Vietje
OR....
Brad Vietje
... use a 4" x 36" vertical belt sander like Jon Siegel does. Replace the belt with a longer belt and add a 180-degree twist to it, and reverse the direction so it runs UP, away from the sharp edge. Add a narrow buffing wheel with a bit of Tripoli to the same shaft, and now you can sharpen and buff the flute in about 7 seconds.
Unbelievably quick, easy, and stress-free.
Safe spinning,
Brad Vietje
Newbury, VT
Re: OR....
ihmserv
I second this setup,
have been using for a couple of years now and love it for skews.
IAN
for a second there.....
Dick Coers
I thought you were telling us to put a twist in the sanding belt. WHAT? Oh, the v-belt. That's something completely different, never mind. Glad I wasn't thinking the belt on my pants!
jim 9 miles
back before I had a bench grinder, I sharpened everything on a belt sander
Jerry Hall
Here is a slide show link to a jig that uses an old portable belt sander:
https://picasaweb.google.com/jerhall95945/BeltSanderSharpening02#5450798336299674690
I made it for a youth turner as a safe and cheap sharpening alternative.
Below is a picture using the setup to sharpen a skew. Of course you don't get a hollow grind so refining the edge with a hone does not give you the two control points for a good job. But it works, and you can use a fine grit belt. Change to course when reshaping or major cleanup is necessary.
Thought of making another for traveling or demos since it is light weight and handy.
Colin
I modified a stationary sander and grinder to do the same thing. There are a few photos and a brief description in the link. It is now how I sharpen all my gouges as well as skews.
My belt sander conversion
Grant Wilkinson
That's a great re-fit, Colin. I was lucky enough to latch onto a 1" belt sander/grinder, and did something similar to your set up. I don't believe that I would have know how to change motor windings to reverse the belt. The motor I had contained a wiring diagram and all I had to do was follow it.
Brad Vietje
Brad Vietje
Nice, Colin,
Glad to see you found a way to reverse the motor. I have found that with all the tools and v-block positions either numbered or color coded, it only takes about 6 - 8 seconds to resharpen a tool with these systems. If you employ a foot switch, and keep it near the lathe while turning, the ease and speed of this method is a real bonus.
Safe spinning,
Brad Vietje
Newbury, VT
