Dental handpiece for piercing?
Colin
I would like to have a go at doing some piercing. I only have a dremel and trials with that have not been so successful.
Researching this I have seen comments about using high speed dental drills to do this with. Searching on my favourite auction site there are loads of them at very reasonable prices.
Before I buy one can anyone tell me how to connect it to my compressor? They all seem to have 4 connection holes, presumably water in and out and air in and out. Do I need the water for cooling? or just accept that the bearings may not last.
Any advice would be most welcome.
Re: Dental handpiece for piercing?
Bill Blasic
Bill Blasic
Colin,
At your auction site try a search for this:
Dental Handpiece Control System With Regulator/Filter
At the very least this should show you everything you need.
Bill
Rob Wallace
Rob Wallace
One thing that you need to consider is the careful regulation of air pressure - these handpieces are designed to run at pressures between 30 and 40 p.s.i. and not much higher. If you exceed the design pressure, there is a very good chance you will destroy or otherwise permanently damage the turbine, which can be quite costly to replace. My next door neighbor is a dentist, and that was his first advice to me - be absolutely sure you have excellent air pressure regulation! Your system should also provide some form of filtration - any particles entering the handpiece can result in catastrophic failure!
Having no experience with your 'water-in, water out' question regarding cooling (or even the need for cooling), I can only say that there are many, many people who simply use air pressure alone to drive their handpieces. A different issue which may be of more immediate concern is whether or not the handpiece/turbine must be lubricated or not. I would research this requirement for whatever handpiece you might be considering to purchase. The compatibility of connector configurations is also important; be absolutely sure you check on the supply connector's hole pattern and its compatibility with the handpiece, since there are several different types, which are often related to the different brands of handpieces - there is no one universal system!
Good luck!
Rob
Don Evans
If this is really a handpiece that is used by a dentist, then the water used is for cooling the tooth the dentist is working on! It is NOT used for the bearings in the handpiece!!! All true dentist drills I have seen have oilless bearings in them, as lubing them with oil would cause the handpiece to spit oil into a persons mouth, uck.... don't want that.
Anyway, you will NOT need a water connection nor do you want one for piecing woodwork.....
Some handpieces even have a connection for fiber optic light.
All you will need is air in connection, it will come from the compressor then a regulator then a small filter then to the handpiece via clear hose of appropriate size. You can also add a dryer cartridge in the line after the filter if you want to. You can purchase all of this at big box and local hardware store, nothing special about them. You will need a meter on the regulator to tell how much air pressure you are putting to the handpiece. If no instructions come with it start with 20 psi, use your ears to determine if you have no instructions with it but I would not run it with more than 25 psi. If you've ever been to the dentist you should be able to keep it in the safe range just be listening to it.
Remember that this units do NOT have much torque, they are for working with thin wood (1/16") not hogging out work.
Don
Don Evans
I should have added that when you get one of these, you'll see a little hole in it at head end that is maybe 1/32" that is where the water comes out, it doesn't go through the head of the drill. If you see a dull looking little lens in same area also 1/32" or so that is the place light comes out.
If you'll share the place and which you are thinking of purchasing I'll take a look at it and give opinion. My email is above if you want to email me I'll be likely to see the message.
fyi, I'm not in market for one as I have 3, so I will not be bidding against you, ha...
Mike foster
Some good info has already been posted,however a little mid-information as well. I am a dentist and a piercer as well. Most dental Handpieces actually do require oiling but we have machines that clean,lubricate (with oil spray), then purge the excess oil before sterilizing them. There are Handpieces that have ceramic bearings, like the NSK, which requires no oil. I use the kind that needs oil, but have no problems with oil on my work. Just run the Handpiece a little to ensure the excess oil is expelled. Use a light touch, as mentioned as they are not meant for heavy lifting. The bearings do eventually go, but can be replaced fairly easily. A new turbine costs about 125-175$.
Re: Dental handpiece for piercing? *LINK*
Colin
Thanks everyone for the advice. Lots more to think about. This is a link to one for about $23 and at that price it is a cheap bit of experimentation.
UK eBay Link
Charlie Drake
Colin, lots of good advice already given. My experience has been-purchased a couple of cheap dental drills (from China on ebay) and a self contained pressure regulator/pressure gauge (ebay-I think about $20)-also purchased the special air/water adapter (still ebay). Hooked up this adapter to the regulator and works fine. I add a drop of oil into the air hose every couple of hours (after adding the oil, I run the drill for a couple of minutes so the excess oil sprays out the end of the drill) and the whole thing has been running for a number of months.
Good luck, Charlie
Jim Evans
Jim Evans
How would you power one of these?
