Bugs in Wood
Bugs in Wood
Bugs in Wood
Nick Tuzzolino
I have a small 10"x10"x4" piece of juniper I won at a raffle last weekend. This AM it had several little dusty mounds coming through the bark and sides and several more piles (tiny) of this dust on my bench. Obviously an insect of some sort, but have never encountered something like this. What to do? I has some nice color, etc, but cost nothing. Should I just dump it or??
Re: Bugs in Wood
Re: Bugs in Wood
Jorge
There are several things you can try, one give it short blast in a micro wave, another is to put it in a plastic pail where a small dish with gasoline, cover tight and after a few days hopefully all the critters will be gone.
Or you can turn it right away, thing and saturate it with CA or diluted lacquer.
Make sure to burn the shavings immediately, those powder beetles spread to other wood around.
Re: Bugs in Wood
Store it away for a while ....
JamieDonaldson
..in a sealed plastic bag including several moth balls.
Re: Bugs in Wood
Walt Bennett
Re: Store it away for a while ....
Walt Bennett
Moth balls are the easiest and least intrusive. Something else to note is that wood has to have some moisture for these critters to stay alive.
Re: Bugs in Wood
Re: Bugs in Wood
Bob Lalonde
Nick, even though there are good ideas here, it's not worth taking the chance they will get into your building. Throw it away. Bob.
Re: Bugs in Wood
THANKS
Nick Tuzzolino
Thanks for the options. This bug thing is new to me.
Re: Bugs in Wood
Skip Beardsley
Nick,
I have the same problem with a beautiful piece of Big Leaf Maple Burl. Posted here a couple of weeks age.
Here is what I am trying. I turned the burl upside down and put a chalk line to divide it in half. With an eye dropper and later with a hypodermic needle I placed lacquer thinner in the holes in one half and DNA in the other. This approach came from several posts here on WC. I let is sit bottom side up for a bit and then turned it over and placed it on a black plastic bag on my bench. After the first dose, I noted substantially fewer mounds and it didn't seem to be better or worse on one side or the other.
I have continued until this morning I had only one pile. I plan to get that one little critter and then pit it in an out of the way place on plastic for a couple of weeks to make sure no egg have hatched.
It seems to be working and planned to post here the results when completed
Skip
Re: Bugs in Wood
Brad Vietje
Careful!  Could be Powder Post Beetles!
Brad Vietje
Be Careful, and look for more of these "little piles"... I'd get that wood sealed up in plastic, and if possible, out of the building if you rely on wood framing or a timber frame to hold the roof up! If you start seeing any spread -- and it's starting to get away from you, take infected pieces outside and BURN IT!!!!!
These little critters are not all that hard to kill, but they can spread to other parts of your shop or house. End result could be a frame collapse or other extensive damage.
I just built a timber frame (a.k.a. "Post & Beam") house, made from a re-purposed 1852 Hemlock frame from an old house being torn down. We had all sorts of nice-looking beams left over, and stickered out under cover in the yard, with hopes of using them to build a pergola, a porch, and even a chicken coop. Just before snowflakes flew, I checked, and found many of them were infested with powder-post beetles.
On New Year's eve, we have a beauty of a bonfire! I'm not letting these little buggers infest my house in order to save a few dozen old beams.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Bugs in Wood
Re: Bugs in Wood
don central illinois
If you decide to turn it right away, make sure you wear your face shield! DAMHIKT!
Re: Bugs in Wood
Re: THANKS
jim 9 miles
Wonder if you put in freezor for about a week would that work?
Re: Bugs in Wood
Dale Jablonski
Re: THANKS
dale jablonski
nope, not near cold enough. I wouldn't take a chance with powder beatles.
Re: Bugs in Wood
Re: Bugs in Wood
Lewis Dodd
Well, I have addressed this a couple of times. If I am turning it and itters appear, I spray i with Diazinon (sp) and continue turning in about 15 minutes. Otherwise I seal it in a plastic bag with an open bottle of household ammonia for a day or two.
