Re: OT DVD to Ipad Question - OT
Scott Greaves in Blackfoot Idaho
Hi Barbara!
Here's how I do it: I use two different programs you can download from the Internet for free. The first program is DVDFab. When you download it you get a 30-day trial of the whole program, but after that expires you can still use the Decrypter part of it which doesn't expire. Put your DVD in the computer, then start DVDFab. It will scan the DVD and set it as the source. I like to rip to an ISO file, which is an image file of the entire disk. So for target choose to rip to an ISO and set aside a folder for your ISO files. Hit start and it does it's thing. This gets the data from the DVD onto the computer in a usable format.
Then I use a program called Handbrake. When you open Handbrake it helps to set your target directory before you do anything. Choose tools>Options>General, and set the directory you will send your new file to. I set up a directory called ipad just so I would know the files there are for my iPad. Then hit the "Source" button in the top left corner, choose the ISO file you made with DVDFab earlier, and hit open. This sets the ISO as your source file. Then over on the right hand side of the screen in Handbrake there is a list of "Presets". Click on the one for iPad, and it will load the parameters for the optimum iPad file in the program. Then hit "Start" in the upper left of the screen. It will take a while to do this, but what you end up with is a MP4 file optimized for the iPad. Once you have this file, drag and drop it into iTunes, then hook your iPad to your computer and drag and drop the file from iTunes to your iPad. Once it's on there, you will find it under the "Videos" app button.
I hope this is clearer than mud for you. Once you try it its much simpler than it sounds. Just Google for DVDFab and Handbrake. They are both free. If you're not seeing DVDFab for free, Google "DVDFab free".
I figured this all out in the last week because I want to take some of my videos with me on vacation for the long flight. You can't play games ALL the time! ;-)
Good Luck!
Scott.
