Finding the bottom of the bowl
Re: Finding the bottom of the bowl
Re: Finding the bottom of the bowl *LINK*
Doc Green
Very clever, and quite simple to build!
The link below will take you to three other versions that require a bit more in the way of construction.
Doc's Website, Thickness gauges
I don't have any trouble finding the bottom. I reverse the bowl and then just turn until I can see it. :)
Hal Taylor
Very useful and clever idea. Thanks for sharing. Even though, I'll bet I can still make a funnel!
Dick Hines
dick hines
Finding the bottom is easy. Not finding the bottom is the hard part. :D
Re: Finding the bottom of the bowl*LINK*
Geoff Kelk
Here is a very quick and easy method that works very well for me...
www.woodlotharvest.com/Index/Measuring_base_Thickness.html
Too easy!     (thanks!)
Two or three more
I put a piece of blue tape on the side of the ways under the chuck. Use a square to put a mark on the tape representing the face of the jaws. Turn the bowl to the point the rim is established and plumb that down to the tape. Then you can measure the total depth of the bowl, and then the depth of the bowl by using the straight edge across the rim. Then compare the interior depth of the bowl to the total depth and you can see the remaining thickness of the bottom.
Similar to one of the methods above, you can set the tailstock at the far end of the ways and cut a dowel to the length of distance between the face of the chuck jaws and some known fixed point on the the tailstock. I ignore the quill and use the front edge of he casting where the quill enters. That way I don't have to set the quill correctly each time. Then you turn the bowl and from time to time touch the dowel tot eh interior bottom of the bowl and compare the other end to the known spot on the tailstock. You could mark graduations on the dowel but I just eyeball it. (I like this method because it parks the tailstock back out of the way and does not require moving it.)
Another way I measure the bottom is to use a gauge I made that looks a lot like a giant pair of scissors. When I reverse chuck onto the Cole jaws, I can reach between them and measure the bottom thickness.
I like it...
GaryG in MD
Very simple, quick, and to the point.
Thanks for the idea, Gary
Randy Gleckler
Cool Idea, I will have to file that in memory to use. Thanks
