Nova DVR Riser Blocks
Bob Moffett
Bob Moffett
I have a Nova DVR and would like to increase the swing from 16" to 20" or 24" inches. Does anyone know of a source for riser blocks for the DVR? What is the address that I can go to to buy a reconditioned DVR? Thanks in advance
Re: Nova DVR Riser Blocks
Alan Zenreich
Alan Zenreich
http://www.novatoolsusa.com/Reconditioned-Products_c10.htm
NovaToolsUSA has a reconditioned DVR XP for $1700
Woodcraft has new DVR XP units on sale right now for $1900
http://www.woodcraft.com/Product/2005485/22172/Nova-DVR-XP-Lathe.aspx
They are selling the new DVR 2024 for $3000
Steven Antonucci
You'd need to swap most of the lathe
steven antonucci
If you had 2" risers, you'd have to get a banjo riser, or a really long tool rest post to make up the difference. The cam nut that holds the pivot would also need to be longer by 2". And your tailstock would be too low without a riser.
Not a simple upgrade...
Steve
Nova 3000 user since 2000... and I've had my lathe in pieces numerous times.
Mike Stafford
Mike Stafford
Bob, just bite the bullet and spend some of that moldy old money you have and buy a new lathe. I recommend getting a Robust or a Stubby.
Lan will help you move it......
Bob I've never heard of anyone making riser blocks for the DVR. I have done it for an older lathe and it's a lot of work. It requires a riser for the headstock and tailstock. Then requires extensions for the bolts that lock them down. Then you need a custom tool rest with longer post. I built my risers out of MDF and then added all the extra bolts. A lot of work and unless you make the risers out of steel you will have some flex and vibration.
Rotate the head
Jorge
I am assuming that the DVR has the same rotate the head capability of the Nova 3000, I did make a number of over 16" bowls and platters out board, Had to improvise a tool rest, but it was not that hard and did the job.
A lot simpler than making several raising blocks.
Lan Brady
Mike,
I done told him the same thing. Thanks!!!
Lan
Re: Rotate the head
Henry (Raleigh, NC)
Same experience as Jorge.
I only did one this way - but I did a 20" shallow bowl on a Nova 3000 by rotating the head, improvising support for the tool rest, living with some vibration, and sanding a lot more than I like to.
Henry
Re: Rotate the head
Ditto what they said. I bought the outrigger support for my Nova 3000 but it vibrated too much so I rigged up a piece of all-thread rod with nuts to go from the floor to the tool rest to steady it.
The large platter I did required that I remove the blank in order to reposition the tool rest to clean up the back side. It was not the best way to go which is why I saved my money and bought the Powermatic 3520A.
Amen to that!
Jorge
I did same thing, except I got the PM 3520 b.
It is a total compatibility between the Nova 3000 tool rests, chuck adapters faceplates etc. they all fit the PM 3520 b. Not so with a Oneway...
Bob Moffett
Re: Amen to that!
Bob Moffett
Thanks for all the good suggestions. From the comments, I gather that I didn't have such a great idea, but Mike, why would I want a Stubby boat anchor? lol
